Sounds good to me
as does this Rexxer thingy
Sounds good to me
I can't believe I've just come across this thread now. I'm in Melbourne too. Who and where is this MPR that you speak of. I need to contact them ASAP. Where in Melbourne are you Man Hands ? I wouldn't mind catching up with you for a ride and a face to face chat on this topic.
MPR Bikes - End of Fourth Ave, Sunshine ph. 9311 4422.
I'm in Broadmeadows mate, a ride sounds good. I was thinking about going out this Sunday but not sure what the weather's gonna be like. At this stage the forecast says showers and coldness!
That's cool. I'm from Greensborough but I'm living in Epping at the moment and I work in Campbellfield so pretty close hey.
Unfortunately I recently damaged my knee that I had reconstructed a few years ago so I may be out of action for a few weeks.
I'm currently running a LV De-cat & Akrapovics + a DNA filter so I'm very interested in what MPR can do in regards to mapping.
I do also have a Kevxtx AIT mod on the DD which is really good in regards to the fuelling but obviously doesn't resolve the mapping
issues we have with these bikes.
Is there an update on performance and did you have it dyno'ed?
I hope to have some before & after dyno data to report on in a few days time.
Bike is currently at the shop and waiting for a revised to map to suit...
Bike Garage:
2009 Aprilia Dorsoduro - Mods: Akra Ti/CF cans, LV De-Cat, FatDuc, STM Slipper Clutch (w/ see thru!), Samco Hoses, RSV4-R Factory Forged Rims, Power Pures, Matris Fork Inserts, Factory Shock, Braking SK2 Superlights, ProTaper Bars, DNA Air Filter, 'Big Mouth' Air Box, Gel Seat, Evo-Tech FE, R&G Sliders, Ballastic Battery, Ti Nuts & Bolts, Lightech Alloy Nuts & Bolts, Stompgrip, Factory Carbon F... Komptech Tail fairing, OEM less 25.2kgs and counting !
2007 CBR1000RR - Matte Black - Modified Track-Ho.
@OP - Thanks for the post....
Food for thought
I've got a 2012 Shiver and am loving it....might look into this in the future![]()
BLOG = http://bitsar.blogspot.com.au
Life is Complex
:: {It has an (i)maginary component && a (R)eal component}
Guys, look into something called a FatDuc modifier or manipulator. Basically it is the same thing as a memjet sort of variable resistor but instead of messing with base fueling data (like intake air temp) it works by adding a variable but small amount of resistance to the return signal of the 02 sensor to the ECU, allowing you to slightly or massively richen mixture at cruise without an effect on wfo fueling...aka...a wet dream for these bikes. We will be adding them soon to our store but if you want one right now I have tested the www.fatduc.com version on several 750cc motors now with better results than any other single device tested in last three or so years. if I had a DD750 street or track bike I would have this simple <$100 solution on my bike. If you try to order from fatduc guy just tell him you have a ducati, he seems to think this trick only works on ducs. If you are cheap like me it is a simply a variable resistor attached to the return signal wire between the lambda probe and the ecu. I am so tired of watching you guys suffer and done hoping for a map update that actually works...try it my way, you may be absolutely floored at how good it runs. Since my Vespa is 99% closed loop I am running a similar trick on it and hopefully will still be bale to run the more or less stock efi this way even under boost this winter...
Micah Shoemaker
699 W. San Antonio
New Braunfels, TX 78130
830-626-3966
micah@af1racing.com
2011 Dorsoduro 750 - Black
"I contend that we are both atheists. I just believe in one fewer gods than you do. When you understand why you dismiss all the other possible gods, you will understand why I dismiss yours.” - Stephen F. Roberts
I need for some of you guys to try this out and let me know/us all know your thoughts. Mine were damn near perfection, ten minute install time, amazing tuneability range since stock feedback loop is SO lean...no bad things I have run across yet. Like I said before just contact the guy at www.fatduc.com and tell him you need Duc-02 part number, leave set where it comes stock and go for a ride, the difference for me is night and day. I have been playing with this conceptually for some time with no ill effects so getting pretty confident I/we are on the right track. Also as stated if you are as cheap as me just getting a little variable resistor and splicing it in is easy too, it simply reduces the return signal voltage a small amount and from there ecu richens fueling a small amount to hit it's fluctuating target value again but this time it is hitting the af/r WE want and thinking it hit the af/r IT wants. WE know better what we want than the bike does unfortunately.
I have debated for some time going public with this one and am probably making a poor financial decision by not keeping it a secret but, since there are so few DD or SL riders that want to play mod games near me I need more global feedback. I have been hoping for/really hoping for...simply a better OEM mapping to come out so this can be fixed properly, it seems unlikely now that we are a third of a decade down this road so fuck it, the wait is over. This little trick works on a LOT of different closed loop systems as long as you can read a schematic and use a multimeter with proficiency. Get cracking boys and girls, report back in this thread in the coming weeks and months!
Micah Shoemaker
699 W. San Antonio
830-626-3966
micah@af1racing.com
Just placed my order with Jason from FatDuc.
i will post my results and opinion as soon as i have installed and tested it.
first I have to fix my exhaust mount from the roads italia mufflers, i lost it somwhere on the road today doing a high speed run at 225km/h (140mph)
that was a real scary moment![]()
Aprilia Shiver My10
Pazzo levers, Roads Italia carbon muflers, LV-decat, DNA filter, Fat Duc, Matris cartridge set, RBT rear sets, Seat cover, OZ Factory wheels.
Goodie's to follow: 15T sprocket, ProBolt titanium/alu bolt and nut conversion, carbon parts.
Conclusion: Making a factory Shiver
Am I correct in saying it is a Linear variable resistor ? or analog...I'm going to have a play.![]()
I used to be indecisive but now I'm not so sure?.
