Results 1 to 15 of 22
Thread: How do you fix...
    Aug 2005
    Perth W/Australia
    How do you fix...
    Those threaded insert in the rear frame that the seat bolts into?
    I have one spinning
    Who said you get slower as you get older!
    apriliaforum expert DR-JEKL's Avatar
    Nov 2009
    Newcastle NSW Australia
    Quote Originally Posted by RossGuzzi View Post
    I have one spinning
    You can buy these or make something up similiar:
    http://www.af1racing.com/store/userm...atclipinfo.htm
    2003 Aprilia Falco
    2002 Lexus IS300
    Wouldn't mind a R34 GTR for my next toy!
    apriliaforum prov-nov slr_daz's Avatar
    Nov 2003
    Sydney Australia
    Ross if you can get at it try a centre punch and hammer, pop it in about 4 locations if you can.
    Cheers
    Aug 2005
    Perth W/Australia
    no good. Any other recommendations? Can they be renewed?
    Sydney, Australia
    Yes the nuts can be bought from Dave, (?), or AF1, (which I've bought before), but you you need the special tool. The nuts are called rivnuts, and unfortunately I don't have the tool. If you buy a headlight/dash sub frame for a T or RSV, you need to purchase the rivnuts and then install them into it.
    apriliaforum expert Falcopops's Avatar
    May 2006
    Townsville Australia
    Not tried it myself, but could you run a bolt through it from below then tighten a nut down hard to try to spread the rivnut a bit more to get it to re-grip.
    I'd go with DR-JKL's suggestion, you can make the yourself for pennies with a quick visit to bunnings.
    "I like to put a little silicone grease on the seals, too, to keep them looking young and fresh like a prom queen." - SoulDaddy
    Sydney, Australia
    You will need a high tensile strength bolt at the very least, (which is the principle of the special tool by the way), and I did try on one of the rivnuts I bought for the fdash subframe, but to me, no luck in squashing it. I'm sure it can be done though without the special tool.
    apriliaforum expert Brinks_2's Avatar
    Oct 2007
    Perth Western Australia
    Ross let me know how you get on cause I have the zebra gun an rivnuts available to me.
    2 eyes,2ears,2hands,2feet----TWO CYLINDERS
    ----------------------------------------------------Falco Mods-K&N Filter,Open airbox,SL Carbons,Penske 8983, carbon front mudguard, dash,top yoke and sprocket cover, bellypan, billet bar ends and levers, tint screen, PCIII , braided brake lines , Evoluzione clutch slave, Sargeant seat, tail tidy, Vario bars, Mille swinger, Rad-cooler guards more to come
    ----------------------------------------------------DD 1200 - Gel seat, Arrows & map, shock tube, EVO Tail tidy, rad and oil guard, DNA Stage 2, Lightech bolt kit.
    You do not have to have a long neck to be a goose
    Sydney, Australia
    Quote Originally Posted by Brinks_2 View Post
    There you go.....sorted!!!
    Aug 2005
    Perth W/Australia
    Brinks my man !
    Perhaps you could catch up when it suits you. I still have the 50 for you too.
    Just thinking out loud. Wouldn`t a new one spin too ?
    Sep 2005
    Minnesota
    I had the same problem and didn't want to bother with a special tool, so I used a clip on nut and an allen head bolt.
    I ended up liking the solution better than the OEM.
    This space for rent
    Oct 2007
    Ross , it shouldn't spin if the right size is used. UMMMMMM my issue at the moment tho is no front brake until I get the master delivered and installed. So what I'm saying is I can't get up to your place at the moment, unless my parts get here this week. I'll give ya a call this arvo if I have still got ya number (new mobile)
    Aug 2005
    Perth W/Australia
    no problem, not a rush to get it done. I will pm you my number.
    Cheers.
    Aug 2005
    Perth W/Australia
    I fixed it by threading in a long HT bolt then tightened a nut down onto the lip of the rivnut. It squashed it onto the frame enough to stop it spinning. Job done !
    apriliaforum Junkie Twins's Avatar
    Sep 2009
    Newcastle Australia
    Hi Ross, I have a 'Wurth' brand rivnut tool and assortment that I purchased some 15 years ago to fit a steering damper to my 96 GSXR. I remember the kit was about $300.00 then, but the alternatives sounded nasty! It needed a rivnut in the frame (hole was already factory drilled) to mount the boss for the damper. I will take a picture of the kit with all the rivnut sizes and you can let me know what you want or I can send the whole kit over and you can send it back when your done. Let me know cheers Doug.
    "What ever you do right will be correct"
    Current Bikes. 2002 RSV Mille R, 2001 Falco, 2002 SR50 Ditech SBK replica.
