I know a few things are interchangable between the two, but now I wonder if the sprockets are the same?
Lot's of RSV4 sprocets out there, a lot fewer for the Tuono R.
Front is the same at least but there can't be any problem finding sprockets for the Tuono?!
JT sprockets available in a variety of sizes
Front is called JTF704 and rear is called JTR702, any bike parts dealer can get them for you!
Rear also fits Mana850, dorsoduro750, shiver750 and so on..
Front also fits BMW650/800(twin), RSV4 and so on...
There are LOADS of sprockets for the RSV2/Tuono2
When exiting the corner I suddenly ran out of talent and fell off the bike.
2008 Tuono Factory R - 141whp, 131Nm! Eleventwentyseven No.1
2007 Tuono 1000 R - 129whp, 97Nm The wife's ride.
Yes, there is stil a lot availbale but the list shrinks with my requirements; I need a 520 sprocket, 42t, with reasonable shipping to Norway.
I just know from experience that the options increase if I can add other models.
For 520 chain use JTF705 up front and JTR703 for rear. Problem is; there isn't 42 available for rear. 40 or 44 what I know.
MAXMC scandinavia might be good enough?
What I can see, the rear sprocket hub(sprocket carrier) for the rsv2 and rsv4 are the same in terms of part no. AP8125730.
This would indicate that you can use RSV4 rear too. However I havn't tried..
If so, there is Talon UK who produces "520" sprocket for RSV4 with a variety of teeth including 42.
Hope this helps
I know the front fender of a RSV4 will fit on a 2nd gen Tuono...
Good luck with the sprockets!
It is my first twin, and I'm never going back.
Got a Golden Tallon 42 rear. Thanks for the info.
