Page 1 of 4 123 ... LastLast
Results 1 to 15 of 47
Thread: Replacement Demand Sensor Re-call - RSV4 AND Tuono V4
    apriliaforum Member TZsparky's Avatar
    Oct 2010
    Suffolk
    Exclamation Replacement Demand Sensor Re-call - RSV4 AND Tuono V4
    Hi all,
    Just found this thread on the AF1 RSV4 forum.
    http://www.apriliaforum.com/forums/s...Sensor-Re-call
    Has anybody been affected or know anything more?
    Apparently only a certain range of VIN numbers are affected - any one know the number range?
    Tuono V4R aPRC, Factory Gen 2 V2 B4 the V4
    www.tuonoworld.com
    apriliaforum expert Micke65's Avatar
    Aug 2010
    Sweden
    Mine is in for replacement sensor ..
    apriliaforum expert Hinckley's Avatar
    Feb 2009
    Northamptonshire, UK
    Had mine changed last year, not had a recall letter.
    Demand sensor failure was a common problem last year for many RSV4's and some early production TV4's.
    As far as I remember it was a known bad batch from MM, I don't know the chassis range affected but aprilia have known about the faulty sensors for well over seven months, they were aware in October 2011 that mine was in the affected chassis range - I'd presume only bikes from the initial TV4 production batch have been affected.
    If what I was told at the time was correct, it was suggested that not all bikes will be affected as there was more than one batch used during initial TV4 production.
    The demand sensor is a common part to the Shiver, DD, RSV4, TV4 and DD1200 range.
    Sold: Black RSV 02
    Sold: Silver Shiver 09
    Present: Black RS250 98
    Present: Black Tuono V4R APRC 11
    apriliaforum Member Rayzor61's Avatar
    Jan 2010
    Yardley, PA USA
    What is it?
    TRIUMPH NUTHEAD, APRILIA NEWBIE!
    Current Stable
    2012 Triumph Tiger Explorer 1200 - Main Rider
    2009 Tuono Orange Crush - For Sale
    Previous Kickers:
    2011 Aprilia Shiver
    2012 Tuono V4R
    2009 Aprilia Mana 850
    2009 Harley Street Glide
    2009 Suzuki DRZ 400S
    2011 Ducati Multi S Touring
    2007 V2 Tuono Dialblo Black
    2002 - 2007 Triumph Speed triples (6)
    2008 Triumph Scrambler
    2010 Triumph Thunderbird
    2010 Triumph Tiger 1050
    1979 to Current - Triumphs entire Lineup since 1979
    2010 KTM Adventure R
    KTM Supermoto 950 R
    The list goes on!
    Auckland, New Zealand
    I assume this is not the TPS???
    My dealer told me it was the TPS being replaced under the recall. But that doesn't seem correct
    ScottyDog
    In The Garage
    1. Tuono V4 1100 RF, stock gearing, Austin Racing GP2R pipe, Race ECU, heated grips, CRG Bar End mirrors, Hepco-Becker sports Rack with Givi Top box when touring, Baher Intercom, Nitrous kit, super charger, shitty Chinese folding levers & a flashy sticker that makes me faster...
    2. Merc C63 Coupe 507 AMG (Currently in repair)
    3. Toyota Prado VX SUV
    Feb 2009
    Throttle demand sensor/throttle position sensor, left front of the engine behind the fairing panel.
    It's a twin potentiometer that converts twist grip action to digital signals (4) for the ECU.
    Diagnostic by navigator on failed units reveals inconsistent or no reading from one of the white or blue tracks, either being enough to trigger the urgent service warning.
    As aprilia know which bikes are likely to be affected within a selected chassis range, the failure rate must be high to trigger a recall, I know my dealer has changed a large number fitted to bikes from the first batch.
    Sold: Black RSV 02
    apriliaforum Member ASHTON's Avatar
    Oct 2004
    Bucks UK
    Could this trigger DSB 08 on dashboard diagnostics?
    Feb 2009
    Quote Originally Posted by ASHTON View Post
    I don't know however as far as I understand the code DSB08 relates to Oil Pressure.
    Quote Originally Posted by amauri
    FYI, The error codes displayed or stored by the dash are only related to the immobilizer (DSB 01-03), internal controller fault (DSB 04) and oil pressure sensor (DSB 07&08). DSB 05&06 is not yet used.
    All other errors pertaining to engine sensors, ride by wire, FI or Ign are stored in the ECU. The only way to display those errors is with the AXONE or Navigator.
    Sold: Black RSV 02
    Oct 2010
    Suffolk
    Had a recall letter from Aprilia yesterday:
    "Dear Customer,
    To ensure efficiency of its products over time, Aprilia... have identified the opportunity to perform an upgrade of the electrical system characteristics of the motorcycle. The measure is totally free and consists of simply replacing the throttle grip position sensor..."
    www.tuonoworld.com
    Mar 2012
    Muskegon, MI
    Did the letter mention the VIN# Range? Or is it just 2011 bikes?
    Oct 2010
    Suffolk
    No mention of VIN apart from mine specifically and no mention of what year of manufacture, so I guess you just have to wait and see if you get a letter! Maybe dealers have a list of VIN numbers affected?
    www.tuonoworld.com
    Feb 2009
    I'm in the low 800's, I got a recall letter yesterday, which seems a bit barmy as mines already been done, but - hey-ho my dealer will sort out if it needs changing - again.
    Sold: Black RSV 02
    Apr 2012
    England
    Got mine yesterday - my VIN is in the high 900's
    Jul 2011
    Honiton
    I got the recall letter on Saturday, mine is booked in for replacement of the demand sensor.
    Cheers,
    Mark
    Yellow Tuono V4
    Austin Racing full system, Power Commander 5, Ohlins shock, Pazzo levers, Rizoma bar end mirror, HID headlamps, LED rear light/indicators, Evo Tech tail tidy/Front spindle/swing arm protection, Austin Racing rear sets/race pattern, AFAM 520 conversion 16/45, OZ forged wheels, SRS crash protection, Pirelli Diablo Supercorsa tyres, RSV4 bellyPan, Ohlins RSV4 forks, Brembo M4 calipers, full Aprilia carbon fibre set, Ohlins steering damper, GB Racing engine covers, BMC air filter, Rizoma front sprocket cover, Gilles gear lever support, SCM quick action throttle, Brembo HPK discs with SBS pads, HEL brake lines, Luimoto seat, Techspec tank pads.
    apriliaforum expert Roadcraft's Avatar
    Jul 2011
    Nottingham U.K
    I was initially told mine wasn't within the number range but I also got a letter on Friday.
    "If I agreed with you we'd BOTH be wrong!!"
    Bikes I currently own...
    Honda ST1100 Instructor bike - Honda CBR600RR-8 Track day bike
    1993 Yamaha GTS1000 modern classic
    1992 CBR900 Fireblade
    1981 Yamaha RD50M - 1979 Honda CX500
    1980 Honda MB50 - 1990 CBR600
    1974 Honda SS50 - 1983 Honda CBX550
    1983 Honda Vf500
    1981 Yamaha RD250LC - 1985 Suzuki GSX550
