Results 1 to 2 of 2
Thread: fuel pump wiring harness problems again
    Feb 2012
    scotland
    hey guys has anybody else come across this problem
    o
    Took bike out today for a run it started fine but when i stopped to fill up with petrol it would not start the fuel pump didnt make its buzz like it usualy does
    so i took seat off and wiggled the wires and lo and behold the pump primed and bike fired right up .
    I had this problem last year so i replaced the harness and it was sorted untill today, I am putting it down to the bike was serviced recently and off course the tank was probably taken off or propped up and this may have pinched the wiring as it enters the unit .. So that said is there a permanant fix for this without having to shell out for a wiring harness every service ..
    Any advice gladly accepted
    Sweden, Linköping
    Do your own service.....
