Results 1 to 15 of 15
Thread: Crankshaft problem :(
    May 2011
    hook
    My moped was making a funny noise the other day so I took off the transmission cover and went to take off the variator and everything was spinning except from the bit I had the locking tool on, I managed to get the nut off and found a big groove cut out of the crankshaft, now I can't take off variator. I have bodged it back on for now, i could replace it but its expensive. also is it a job that i could do myself at home wth basic tools??
    thanks
    Feb 2011
    Manchester
    Are you on about putting a new crankshaft in the bike?
    Full UK Bike licence!!
    Suzuki DRZ400
    Aprilia MX125 2005 40Mph crash now Cat C
    Renthal bars!
    Full Arrow exhaust system
    16/45 final drive
    SBS Brake pads! (Highly recommend!!)
    Aprilia SR50R 2005
    Leo Vince TT
    Malossi X-Drive Special belt
    I was getting...(SR50)(GPS)
    Flat: 54mph (no tuck, light wind)
    Downhill: 57mph (no tuck, no wind)
    Uphill: 44mph on what i would consider a good hill (No tuck, no wind)
    At the moment im getting...(MX125)(Speed'o speed's) 16/45 16/43
    Flat: 82.7mph, 6th gear... No tuck/No wind 87.2mph
    Downhill: 86.2mph sat down but not on the tank... 91mph
    Uphill: 73.6pmh, Steep hill, 5th gear pulling! 77.3mph
    May 2011
    hook
    Yeah, is it a relatively easy job to do?
    Feb 2011
    Manchester
    Not really, Full engine strip down+ if your putting a new crank in you may as well do a full engine rebuild.
    Suzuki DRZ400
    Renthal bars!
    16/45 final drive
    Aprilia SR50R 2005
    Leo Vince TT
    May 2011
    hook
    Yeah that's what I am going to do next weekend
    Banned Snugg's Avatar
    Aug 2007
    Aurora, CO
    Tools aren't usually the problem when doing a bottom end build. Well, some special tools like a heat gun make life a ton easier, but where people usually get hit is the knowledge part. There is a lot more too it than just taking it apart and putting it back together.
    Depends on your mechanical apptitude.
    Feb 2011
    Manchester
    Quote Originally Posted by Snugg View Post
    Crank seal's usually end up going the wrong way round meaning all your hard work is for nothing.
    Suzuki DRZ400
    Renthal bars!
    16/45 final drive
    Aprilia SR50R 2005
    Leo Vince TT
    May 2011
    hook
    I have Started taking it all apart and I have only just realised that the throttle cable splits into 2 and one goes to the carb and the other goes in near the variator, whats the one near the variator do?
    Aug 2007
    Aurora, CO
    Oil pump, I would not suggest that you try to tackle this project.
    May 2011
    hook
    I'm going to anyway, oh well if I cock it up it doesn't work anyway
    May 2011
    hook
    completed it it's only taken me two weekends
    Feb 2011
    Manchester
    How's it riding then?
    Suzuki DRZ400
    Renthal bars!
    16/45 final drive
    Aprilia SR50R 2005
    Leo Vince TT
    May 2011
    hook
    Not bad, 45mph which isn't as good as it was but I will let it run in properly
    Feb 2011
    Manchester
    Good to hear!... How was it doing everything?
    Suzuki DRZ400
    Renthal bars!
    16/45 final drive
    Aprilia SR50R 2005
    Leo Vince TT
    Aug 2007
    Aurora, CO
    Great to hear! I'm glad you got it done.
