Results 1 to 6 of 6
Thread: [Electrical] Indicator switch?
    apriliaforum Member Ario's Avatar
    Poland
    Hi,
    after winter break my indicators do not work. I checked:
    - bulbs - ok
    - fuse - ok.
    I disconnected the connector going to the switch and voltage is on the green cable only - is that ok? I powered the other connector (female ends) and lights go on and in some one can hear a 'click' which is responsible for lights flashing I assume . When I connect those two back and play with the switch (high beam, horn, pass) you hear those 'clicks' but nit when I use the indicator switch. Hence my assumtion it is broken. How can I check using a multimeter (resistance?) if it works?
    If someone has other ideas they're more than welcome
    apriliaforum expert northern phil's Avatar
    May 2007
    Durham U.K.
    Hearing a click but no indicator would suggest relay to me.
    Poland
    1) how can I diagnose the relay itself?
    2) if relay is down when can I get a replacement (apart from Aprilia service <- time & money are usually not acceptable ) ?
    May 2007
    Durham U.K.
    find the relays, put your ear near it, flick the switch if you get a single click, its fooked. Should click on and off and on and off to work indicators.
    Ebay, bike shop, dealer etc for replacement.
    Poland
    Quote Originally Posted by northern phil View Post
    hmm when I flip the handlebar switch no sound is there hence either fried or bad connection (will clean it to see). two days ago I disconnected the connector to the RH handlebar switch and powered each lead in it. one of them made the bulb go on and other (don't remeber colors) made a 'click' sound but only one.
    Poland
    *solved* disconnected the flasher. cleansed the pins with sandpaper and voila!
