Results 1 to 6 of 6
Thread: Roller scale
    Apr 2010
    Denver, CO
    Roller scale
    Guys
    What scales are you purchasing to check your roller weights?
    Wifes Scoot - 07 Yamaha Vino Classic 4T, 3.5 Gram Sliders
    Previously Owned 06 SR50 Factory SP2 Edition.
    Vancouver BC
    Cheapest digi u can find
    apriliaforum expert NoNameForEver's Avatar
    Sep 2008
    Northern Europe
    I got this one.. Very accurate..
    Glyptocephalus cynoglossus lover
    Quest for no 3D glasses
    Banned Snugg's Avatar
    Aug 2007
    Aurora, CO
    HGT and I both use the 1000 digital scale from Harbor Freight! Perfectly accurate and cheap. $12
    http://www.harborfreight.com/1000-gram-digital-scale-97920.html
    Sep 2008
    Nice weather AT LAST! Winnipeg, MB
    How many decimal places does it measure to (i.e. 6.2gr, 6.25gr or 6.254gr)?
    Anger is an ugly Mistress…
    apriliaforum expert DetonatorTuning's Avatar
    May 2011
    Indiana
    6.2, or single digit south of the decimal point
    2003 SR70
    HGT PFI system w/ Bing 26mm dual injector TB, HGT PFI Regulator, HGT ECU, Malossi ECU for gauges
    Malossi 360 intake manifold, Malossi MHR crank and bearings
    Engine block match ported to Airsal T6 70cc cylinder and Malossi VL 14 reed block
    Exhaust port optimized for Malossi MHR Team II pipe.
    Malossi Multivar 2000 w/ 4.25g Dr Pulley sliders, Malossi Belt
    Malossi Delta clutch, Yellow Malossi springs, MHR weights, White Contrast Spring, Malossi TC, Malossi 15 / 40 gears
    HGT Morini stretch kit and shock riser, Scarabeo 50 16" rear wheel and tire.
    MASSIVE PIXY DUST !!
    Rider; 5-4, 130#'s
