mx125
mx125
Were you going faster before? From what I've seen, that is a normal speed for the mx125
as far as im concerned they should be doing more or less 100mph - their two stroke aswel
is the actual exhaust derestricted? the stock exhaust is usually main restrictor so remove that with a drill and a round phile
also what size jet do u have? whats colour of spark plug after a quick scream down the road?........
OH AND does it feel like the clutch is slipping at higher rpm or speed? maybe the plates are worn
Engine Always Screaming!
