Results 1 to 15 of 16
Thread: 42t sprocket
    apriliaforum expert lanter's Avatar
    May 2009
    Guilford CT
    42t sprocket
    Anyone change the rear sprocket? Im thinking of changing it out to a 42.
    2011 Dorsoduro 1200
    Mar 2012
    Tucson, AZ USA
    What is the stock size?
    May 2009
    Guilford CT
    Stock is 40.
    2011 Dorsoduro 1200
    Yellow Shirt
    Apr 2012
    Bavaria, Germany
    I´ve done it a few days ago. It´s a best bang for the buck thing -> More wheelish now ...
    May 2009
    Guilford CT
    Roku, did you notice any difference with speedo? I'm putting new wheels on soon and figured I'd put on the 42 sprocket at the same time. Thanks
    2011 Dorsoduro 1200
    Yellow Shirt
    Apr 2012
    Bavaria, Germany
    Lanter, I haven`t tested it but I expect the speedo and odometer showing 5% higher values now (42/40). That`s the case when speed is calculated by rpm of the gearbox output shaft. In case speed calculation is based on the ABS sensor it wouldn`t affect speed numbers. I guess the first case more likely.
    Jan 2012
    Houston-Downtown
    Isnt the speedo on the rear wheel hub? If so there won't be a change in speeds when regearing...
    Yellow Shirt
    Apr 2012
    Bavaria, Germany
    Your right. My Dorso has ABS so I´m not sure whether the ABS sensor is used for the speed indicator or if the hall sensor located on the gearbox output shaft does the job (illustratetd in the garage manual)? Are there any Dorsos out there without ABS but a sensor on the back or front wheel? If so then it`s clearly for speed indication also on my Dorso.
    Jan 2012
    Houston-Downtown
    My non abs has the sensor on the rear wheel...
    May 2009
    Guilford CT
    Ok, so if I have the non abs, then speed/mil won't change after 42 swap?
    2011 Dorsoduro 1200
    Jan 2012
    Houston-Downtown
    Yep...
    Feb 2012
    A delaid Sth. Australia
    Hey Lanter, G'day from Australia. Have you fitted the 42 tooth rear ? What do you think of it ? I looked into the sensor on the rear wheel and your speedo will only change if you go with a different size rear wheel /tyre than standard. Has your fuel consumption taken a dive ? Cheers, Chewy.
    May 2009
    Guilford CT
    Quote Originally Posted by Chewy52 View Post
    Waiting for it to arrive from af1 Also new tires and lighter rims going on next.
    2011 Dorsoduro 1200
    apriliaforum prov-nov motardman's Avatar
    Oct 2011
    New Zealand
    Quote Originally Posted by lanter View Post
    How did it go? I was also looking at lighter rims, which ones have you decided on? Personally I thought the Carro V tracks look damn good.
    May 2009
    Guilford CT
    Quote Originally Posted by motardman View Post
    I bought a used pair of the new aprilia three spoke wheels, off a fellow forum member and the wheels are getting sprayed whine red. I'm also having the yellow spring sprayed the same color to match the wheels. They're not as light as the Carro's, but I think about 5 to 6Lbs lighter then the stock 2011 wheels. I'll post some pics soon as I get them back.
    2011 Dorsoduro 1200
