Results 1 to 5 of 5
Thread: Exhaust Mount Nut Locking Clip Needed
    apriliaforum expert shrubman's Avatar
    Nov 2008
    Athens, Georgia USA
    I've lost one of the clips that holds the nut inside the receiving socket of the exhaust mount points on the engine case. How do I shop for a replacement (short of ordering a genuine Aprilia part)?
    Shrubman
    2009 SR50 R Factory
    Engine:
    HGT PFI Conversion
    HGT-Modded Bing 26mm Throttle Body
    Malossi 86CC Cylinder
    Malossi MHR Big Bore Exhaust
    Malossi VL13 Reed Valve
    Pro Porting Intake Manifold and Spacer
    Pro Porting Double Layer "Air Plus" Air Filter
    Transmission:
    Malossi Multivar 2000 MHR Team (2008 Model)
    Malossi 14/39 Primary Gears
    Malossi Delta Clutch
    Malossi Kevlar Belt
    Other:
    Stage 6 Adjustable Shock Riser
    HGT Billet Aluminum Brake Levers
    Buzzetti Side Stand
    Motorkit Rear Hugger
    Banned Snugg's Avatar
    Aug 2007
    Aurora, CO
    Right here on AF1 !!
    That part is called a Stop Ring.
    part number is AF8515007
    apriliaforum expert NoNameForEver's Avatar
    Sep 2008
    Northern Europe
    Short of ordering genuine/stock? Maybe a member have a spare.. Snugg, are you sure that part number is correct? All of the part databases I tried it in does not recognized it..
    Glyptocephalus cynoglossus lover
    Quest for no 3D glasses
    Aug 2007
    Aurora, CO
    Quote Originally Posted by NoNameForEver View Post
    Yes, I'm pretty sure it's correct.
    Here is the Link
    Nov 2008
    Athens, Georgia USA
    There's a typo in Snuggs post. AF... Should read AP.....
    That said, a search of the part number on AF1 yielded nothing, so I guess it would be a special order part.
    That's why I was wondering if there are standard specifications for this type of clip that could be shopped for from other sources.
    Shrubman
    2009 SR50 R Factory
    Engine:
    HGT PFI Conversion
    Transmission:
    Malossi Kevlar Belt
    Other:
    Buzzetti Side Stand
