I seeezzzed up my rear caliper. I have replaced it, but may have the same problemcoming bake on the first ride????? any sugesstions![]()
Read and follow kzmille's guide to bleeding our hydraulics would be where I would start
Make absolutely sure you have free play between the pedal and the master cylinder
Chris
Probability factor now 1:1, normality has been returned. Anything you can’t deal with now is your own problem
Yes, what Anzac said!!!
"As democracy is perfected, the office of the President represents, more and more closely, the inner soul of the people. On some great and glorious day, the plain folks of the land will reach their heart's desire at last and the White House will be occupied by a downright fool and complete narcissistic moron."
- H.L. Mencken, The Baltimore Evening Sun, July 26, 1920
Give no regard to anyone whose forum signature takes up half a page of scooter modifications.
^^Ditto what Gary and Anzac said. At least 1 - 2mm clearance between the pedal and the pump, otherwise fluid can not return from the caliper to the reservoir. This causes drag on disc heating the caliper. As the caliper heats up the fluid expands and cant return to the reservoir, so it goes to the only place it can, putting more pressure on the caliper piston, causing more drag on the disc, creating more heat in the caliper and making the fluid expand more until the rear wheel locks up.
Make sure you do not over fill the reservoir, as mentioned it expands as it heats up. Have seen this on a friends Tuono, but he definitely had WAY too much fluid in the resv.
2011 BMW K1300S
06 Husky SM610 Hooligan Jr.
07 KTM 525 EXC
13 Husaberg TE 300
11 Beta 300 Race Rep 2T Trials
75 Suzuki RL250--OldSchool Trials
Now there are 4 "Cylinders" on my ride, inline of course!
ding, ding, ding, me to!!...i was trying to adjust the pedal height for less pedal travel like my SV, so, i adjusted it...well, seems on these Eyetallion bikes all that does is ENGAGE THE CYLNDER... needless to say, after a 15 min trip on the xway, as i pulled up to the light, it came to a stop, except i wasn't touching EITHER brake!!! so, yeah i hope i didn't smoke the caliper, kinda ate up the rotor a bit...re-adjusted it and the wheel rolled free, course i gots no rear brake for now...
and i'd like to say, the bouncing boooobs sig pic is tough to type to...
rulz, we donn neeeed no steeenkin rulz....
inside rulz!!
you need to adjust the pin in the lever linkage so that it is NOT tight against the master cylinder plunger. Also check the condition of the caliper, that the piston can move freely & seal is in good condition.
"Give me chastity and continence, but not yet." - Saint Augustine (354-430)
So the last shop replaced my master and never adjusted the pushrod. so I smoked the caliper..... I replaced the caliper and now I broke the rod hope I can find one easily.
thanks for the help guys.
any suggestions for cheap rotors???![]()
What makes you think it needs to be replaced?
If it does, just keep an eye on the parts thread.
