Results 1 to 4 of 4
Thread: engine re-seal
    Sep 2011
    essex (uk)
    engine re-seal
    hey guys half way through resealing.my engine but now im.stuck, hows.the best way to undo the bolt behind the clutch.arm as my small ratchet is too big to fit in the space? Didnt know if there were any tricks of the trade!!Cheers!
    apriliaforum Junkie Targa Florio's Avatar
    Feb 2011
    Planet Zorg
    The clutch pivot arm should pull out completely, or buy a smaller extension for your ratchet. The bolt doesn't have to come out completely, just loose from the other crankcase
    Sep 2011
    essex (uk)
    So just give the pivot arm a big jank!!!
    Feb 2011
    Planet Zorg
    No, dont force it if it doesn't want to come out with a firm tug, get the swivel socket and extension bar if you cant reach the bolt, a open ended spanner should do however.
