Thread: Pegaso cube fork oil capacity
    Apr 2012
    leeds
    Hi - I'm replacing the oil in my upside down Pegaso Cube forks. How much do the hold? All help gratefully received. Cheers, David
    apriliaforum Junkie SJL's Avatar
    Jul 2011
    UK
    Hi Davidwa!
    There has been another person doing work on the forks on a US Pegaso cube; the link is here> http://www.apriliaforum.com/forums/s...light=fork+oil
    Cheers,
    Ste
    Apr 2010
    gastonia nc
    Hmmm - doing a fork oil change myself. I drained out 375ml of foul smelling oil from each side.
    Was thinking of using 0w20 Mobil 1 syn. in forks - used it before in Caponord and BMW K1100 forks.
    Any one else use anything besides "fork oil" in their forks?
    Feb 2010
    New Jersey, USA
    I found both mine and my brother's Pegasos to be low on fork oil when I drained them. His was around 410ml, mine 430ml. Granted, some oil is difficult to account for as it clings to the fork spring but that wouldn't account for more than 10-20ml. If you are light in weight, running lower fork oil will soften the front end by making the spring rate more constant. Conversely, more oil will be better suited to heavier loads as it will stiffen at a greater rate near the end of the travel.
    Although the Pegaso service manual only specifies 5W, 20W or any combination of the two, I found thru experimentation that the stock fork oil is approximately straight 5W. Depending on your weight and type of riding, I would use a 5w or 10w motor oil if you cannot get fork oil readily. Since the fork oil never gets up to temperatures, the viscosity will effectively maintain in the cold or "W"inter range. As such, the 0W20 will act more like a 0W fork oil and thus give even less damping than stock.
    Andy
    2000 Pegaso
    Apr 2012
    leeds
    375cc - and a bit soft
    Hi guys - thanks for all your messages.
    I've put 375cc of 10w in and it's comfy but probably too soft.
    I'm going to make it up to 400cc and see how much difference it makes.
    Will let you know.
    All the best,
    David
    Feb 2010
    New Jersey, USA
    I suggest bumping up the oil quantity to 430-450ml as per the service maual. Should firm up the forks, especially deeper into the travel.
    Andy
    2000 Pegaso
    apriliaforum Member koukosnest's Avatar
    Oct 2007
    Greece
    Try 15W or 20W synthetic fork oil:
    http://www.torcousa.com/torco_product/rff.html
    All i want from my birthday is another birthday!
    Apr 2012
    leeds
    Quote Originally Posted by koukosnest View Post
    Hi - I've put 430cc of 10 weight Putoline and it's handling great - and with the missus on the back too (although that's riding it a bit slower...)
    Thanks everyone,
    David
