Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: high tickover help
    Melbourne, Australia
    itdbealoteasierifyouusedsomepunctuation
    I'd like to die on Mars. Just not on impact.
    The appropriate number of cylinders for any motorcycle is two.
    apriliaforum expert ELMOSISU's Avatar
    Oct 2006
    Cottage Grove, OR
    the Idle valve air connections are regular rubber. perhaps 1/2" id ( 20mm?) not hard to get at. disconnect them first, and then bring out the phillips driver to remove the valve.
    2006 Caponord - Rich's custom seat, drilled stock pipes, Catfish "429" map, Braking wave rotors, Rally Raid Bars/fender, Ricor Intiminators, Skidmarx custom windscreen ( propane torch special ), Bags Connection tank bag
    2004 Moto Guzzi Breva 750ie
    Jun 2009
    oldham uk
    Quote Originally Posted by Precis View Post
    s o r r y ................
    Quote Originally Posted by ELMOSISU View Post
    I thought doing this, had springs and things flying around the room?
    Oct 2006
    Cottage Grove, OR
    not so bad if you realize there is a spring loading the plunger in the cylinder. Take it apart slowly and it will go back together just fine. The stepper motor will reset its position when you get it back together, so nothing is too delicate to take apart.
    So empty the room, sweep the floor, cover the motor with a detonation-baffle (clean towel) and wear night-vision goggles?
    Got it!
    Actually I squirted it through with throttle-body cleaner till it ran out clean, so I might just leave well alone.
    Oct 2006
    Cottage Grove, OR
    if it ain't broke, don't fix it..................
    I wish I followed that advice, sometimes
    apriliaforum Member lodom's Avatar
    Jan 2004
    Atlanta, GA
    Mine's doing same. Got it all back together after the R/R upgrade and adding fuse box. It ran fine while checking charging (another story). Then 3 days later again ran fine to the gas station. But when I started it up afterwards it was idling @ 2k. I didn't realize how conditioned I was to that little extra engine braking.
    I'll need to re-remove the take to check my stator connections anyway so I'll have a look at the IA valve and its hosery.
    '03 Caponord
    '07 KTM 300 XC-W
    '07 DR-Z 400S
