Hi it probably a simple question but how do i change the light bulb i took 3 screw out which got me the plastic cover loose but there something blocking it not sure what it is .
You should post this in the Shiver/Dorsoduro 750 subforum. And use the search feature as well.
I searched for you and came up with this http://www.apriliaforum.com/forums/s...ght=light+bulb which I think might hold the answer to your question.
WAFO and good luck.
2011 Dorsoduro 750 - Black
"I contend that we are both atheists. I just believe in one fewer gods than you do. When you understand why you dismiss all the other possible gods, you will understand why I dismiss yours.” - Stephen F. Roberts
"The population of lonely people with eager willingness to be purposefully wrong is not to be underestimated." - Will Assaf
