Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: Few questions reguarding our bikes
  1. #31
    Moderator (ADSUM) Grenadiers's Avatar
    Sep 2008
    Nice weather AT LAST! Winnipeg, MB
    Quote Originally Posted by Aprilia sr50 02 View Post
    Well I've done about 2000 k's with the Leo vince ZX-R exhaust. I'm not really sure how many hrs but it would be a fair few.
    OK, what you may want to do is purchase some good quality Silencer Packing material... The Service Manual recommends that the packing be "...replaced every 50 hours of run-time..." . In reality, pretty much all of us go a lot longer then that... The time most of us check/replace it is when we notice an increase in noise from the pipe.
    Once you got it in, remove and inspect the packing in the Silencer (WEAR GLOVES!!!!). Under that layer, you should/may find a wrapping of steel wool (unless it's been "cooked off"). If needed, it too will have to be replaced.
    Anger is an ugly Mistress…
    06 SR50 (Morini)/AIRSAL 70CC BBK/NGK BR9EIX/My Top Speed-117KPH (GPS)!!
    Rear Rack & Top Case/Buzzetti Side stand/Aprilia Racing Shock W/STR8 65mmRiser/HGT Stretch Kit
    HGT PFI Kit/Malossi MHR Team II Pipe/All Polished Water Pump
    Black HGT Gen 3 Fuel Regulator/Stebel Magnum Horn/Glowshift Elite Gauge
    BING 26mm TBA/BGM Pro Reed Block & Pod Filter
    Polished Aluminum Varo W/Kick start & Pod Filter/HEL Brake Lines
    HGT Red Brake Levers/LED bulbs/BGM LED Tail Light
    Malossi Delta Clutch w/Blue springs/Red Contra spring & TC/MHR Full Circle Crank
    Malossi 15/40 Primary Gears & Multivar w/4.4gr Dr. Pulley Sliders/Kevlar Belt
    Michelin Pilot Sport 140/60 Rear tire w/Dyna Beads & TPMS Sensor
  2. #32
    apriliaforum Junkie Aprilia sr50 02's Avatar
    Dec 2011
    Brisbane,Australia
    I didn't think I got a manual from the shop that put it in. I might have to check on the Leo vince website or something for some instructions, thanks Tim.
    Aprilia SR 50 02 Ditech Morini Engine
    Malossi Variator kit (7.5 Gram rollers)
    Leo Vince Exhaust ZX-R
    Derestriction with 2.80 software
    HGT REGULATOR
    YSS Racing Suspension
    Castrol TTS Racing 1 Oil, NGK-CPR8-E Spark Plug (tried ZMR7AP and doesn't perform as good for me)
  3. #33
    Banned Snugg's Avatar
    Aug 2007
    Aurora, CO
    I hate packing silencers. Like Tim said. Wear gloves, I would also suggest a mask as well.
  4. #34
    apriliaforum expert Cool77's Avatar
    Drummondville,Quebec
    Is it easy to remove metal flange from carbon fiber body on a zx-r?
    Aprilia SR Factory 50 2006 IE Morini Engine type
    13 500KM
    MAX Speed after rod in 92KM/H flat no wind, 104 KM/H tuck
    Malossi BBK + Full Circle Crank since 10 287KM
    Stock Gears
    ECU : Malossi
    Mod : Leo Vince ZX-R Pipe flat black ceramic coated - HGT regulator Gen III - Malossi multivar 2000 - 9.0gr Dr. Pulley rollers - Malossi delta clutch small white spring big white spring w/o tc - Malossi belt - Malossi red foam air filter - ZMR7AP plug - Water trap - Malossi Reed valve VL-12 - Buzzetti side stand - YSS Rear shock.
