Results 1 to 15 of 16
Thread: Go my "new" 2009 rsv1000r factory. Let the modding begin!!!
    apriliaforum newb JET MECH's Avatar
    Mar 2012
    las vegas
    Took delivery of my "new" 2009 left over ape... 7 miles on the odometer!!! All ready have pulled her apart and the modding has started. On the list and ordered is Mivv GP carbon fiber slip on system. BMC hi flow air cleaner, e-vap can removed, MAP 2 enabled, clear brake light, clear rear and front directional covers, Aprilia GP shift linkage kit " my ducati 996 has gp shift so this has to happen..lol " and remove the front reflectors from fender. In due time i will be installing a power commander V and get it dyno tuned or maybe install the auto tune. I have not decided yet we will see....i love this bike already!!! Name:  IMG-20120405-00054.jpg
Size:  52.9 KBName:  IMG-20120406-00055.jpg
Size:  54.8 KBName:  IMG-20120405-00053.jpg
    1999 ducati 996 mono
    2009 Aprilia RSV 1000R FACTORY
    2001 BUELL X1 CUSTOM CAFE BUILD
    2006 HONDA CR250R "FOR PLAY TIME IN THE DIRT"
    Never lend out your bike or your girl. They'll both come back fucked!!!!!
    apriliaforum expert wrx_02's Avatar
    Nov 2008
    Fort Worth Texas
    Depending on what you want to do most people run a 15t front sprocket cause it won't require replacing the chain.
    Street ratio I like a 15t/42t
    Add a 43 or 44 and wow look out now!
    Look at your tires, I know they havent been ridden on but they are over 3 year old. Have fun.
    CMRA #728 Novice
    2006 GSXR 600
    http://www.scracecenter.com/
    2007 SR50 Factory:
    Malossi 70cc Kit, ECU
    Full Circle Racing Crank,
    MHR pipe, White Spring
    7g Dr Pulley Sliders
    1964 Vespa:
    133c/4spd conversion
    Mar 2012
    las vegas
    Thanks for the heads up on the tires and also the gearing recommedation....
    Nov 2008
    Fort Worth Texas
    Quote Originally Posted by JET MECH View Post
    http://www.gearingcommander.com/
    Great site. Load your bike settings and you can see how much top end you will lose by changing the gears. You only loose like 500rpms for 2 teeth in the back I think with a front 15t. But you gain a TON of tq and acceleration. Literally feels like 5 more HP.
    CMRA #728 Novice
    2006 GSXR 600
    2007 SR50 Factory:
    1964 Vespa:
    Jun 2004
    houston, tx
    beautiful bike!
    check into a tail tidy, cheap mod cleans up the tail end.
    AF1 installed my 15t ft sprocket before i picked her up even.
    '00 VFR Sold
    '08 'BUSA Sold
    '10 T Factory
    Mar 2012
    las vegas
    Yes a tidy tail is on the list..
    As you can see i already pulled off that ugly mess of a stock plate bracket..
    apriliaforum expert locknload's Avatar
    Jan 2004
    Christchurch New Zealand
    How come ya just dont ride it for a start. Got 86000 kays on mine
    Nov 2008
    Fort Worth Texas
    Oh and replace your hose clamps while you are tearing it apart.
    At the top of the RSVR section there are stickies, read them all.
    CMRA #728 Novice
    2006 GSXR 600
    2007 SR50 Factory:
    1964 Vespa:
    Jun 2009
    Like that lift table, where did you get it?
    Sorry you think it's intolerant of me to not tolerate your intolerance.
    2007 RSVR 1000- Yeah, It has a few upgrades.....
    We used to earn the things we desired in life. Now we're just encouraged to put our hand in the next guy's pocket.
    - Don't go where trouble is likely to find you.
    - Some people attract trouble. Don't associate with them.
    - If you're minding your own business and trouble finds you anyway, do what it takes to de-escalate and walk away.
    - If walking away isn't a viable option, consider running.
    - If you have considered and/or exhausted all of your other options and you must fight to defend yourself, fight to kill.
    Mar 2012
    las vegas
    Quote Originally Posted by locknload View Post
    Ha,ha.....Not my style to ride a bike stock..The ride home was enough for me to know some changes had to be made. Love this thing though!! But my Duc is still dear to me..
    Mar 2012
    las vegas
    Quote Originally Posted by scubacat View Post
    Bought it on line a few years ago and can't remember which vendor i used. Paid 1k for it and it works like a champ!! Would not be without it now..Pnematic lift controls were included with it....
    Mar 2012
    las vegas
    Oh yeah it is a bitch to find neutral on this thing!!!!Did some research and i figured i will bleed the clutch slave cyclinder and if that does not correct the problem i will investigate if i have the #60 oil jet installed. If so i will order the #40 jet and give that a go.
    apriliaforum expert jmardy's Avatar
    Jun 2011
    San Rafael, California
    OK, I'm a tiny bit jealous of your garage.
    There I said it.
    Marin County, California
    2005 Tuono Factory
    Likes Marin Moto Works
    SaferMoto
    RIP Kenny The Iceman #12
    apriliaforum expert asb2106's Avatar
    May 2010
    Kenosha WI
    The 40 jet did help me with neutral
    apriliaforum Junkie Volfy's Avatar
    Oct 2011
    Houston, TX
    I just love that Red Lion.
    Yes, you need to bleed all the hydraulic circuits, if you haven't already. It probably has been 3-4yrs since they first filled the fluids at the factory. Mine sometimes gets a bit fussy to get neutral, but not really all that bad. The silky smooth gear shifts more than make up for that.
    The cans are a must, but PCV probably won't get you much more than MAP2 already does, so only worth considering if you get the Autotune. Even then, I see it as more of a convenience to let you change fuel mapping easily. I might do it if I ever track the ape regularly and want to run two MAPs on two sets of pipes.
