Results 1 to 4 of 4
Thread: trouble shooting and maintenance
    Mar 2007
    Palos Verdes Est. SoCal
    here you go;
    1.>pdf manuals; get them from AF1
    engine;http://www.af1racing.com/store/Scrip...idproduct=5485
    chassis;http://www.af1racing.com/store/Scrip...idproduct=5495
    free owners manuals;http://www.serviceaprilia.com/public...20Mille%202004
    or
    http://www.whootis.com/index.php?page=rsvrmanuals
    here are Aprilia training manuals, a BIG wiring diagram, graphics, all kinds of good stuff http://www.martinpoll.dk/div_april.htm
    2.>Aprilia fault codes; From ignition off, press and hold the LAP/PASS switch on the left handlebar. Turn on the ignition but don't start the bike ( keeping LAP/PASS held ). After 30 seconds or so the temp display on the dash will display error code numbers or 0 if none are displayed. Note that the codes are cleared after this operation.
    http://img.photobucket.com/albums/v2...ultCodes-1.jpg
    3.>the stator test;
    http://www.apriliaforum.com/forums/s...=1#post2660659
    4.>electrical trouble shooting guide;
    http://www.electrosport.com/technica...ng-diagram.pdf
    5.>here's a discussion on how to synch the throttle bodies
    http://www.apriliaforum.com/forums/s...d.php?t=115421
    6.>removing/bypassing the flapper actuator solenoid;
    http://www.apriliaforum.com/forums/s...d.php?t=149997
    7.>here's a suspension tuning guide;
    http://www.gsxr.com/showthread.php?t=10012
    8.>for bikes, with hard to find neutral;
    http://www.apriliaforum.com/forums/s...tch+slave+seal
    9.>clutch M/C seals;
    http://www.apriliaforum.com/forums/s...ial+m%2Fc+cups
    10.>replace the click type hose clamps with these All stainless ones;
    http://www.af1racing.com/store/Scrip...idproduct=7221
    11.>fuel cap leak post#9;
    http://www.apriliaforum.com/forums/s...t=gas+cap+leak
    12.>Amauri's temp sensor post #3
    http://www.apriliaforum.com/forums/s...42&postcount=7
    13.>the correct brake and clutch fluid is DOT 4
    14.>bleeding clutch and rear brake by kzmille
    http://www.apriliaforum.com/forums/s...ad.php?t=15500
    15.>if you lose your key and need to reprogram the Immobilizer;
    http://www.apriliaforum.com/forums/s...light=blue+key
    16.>list of locksmiths that 'can' cut Aprilia keys
    http://www.apriliaforum.com/forums/s...d.php?t=203485
    17.>flywheel removal with pictures (thanks to uberchicken)
    http://www.apriliaforum.com/forums/s...lywheel&page=9
    18.>Aprilia bearings and seals
    http://www.apriliaforum.com/forums/s...d.php?t=198745
    19.>Clic-R pliers....for all the hose clamps
    http://www.google.com/products?clien...ed=0CBUQrQQwAA
    20.>the exhaust pipe formula
    http://www.apriliaforum.com/forums/s...t=pipe+formula
    21.>manuals for everything thanks to Mille Racer 69;
    http://www.carlsalter.com/motorcycle-manuals.asp
    It takes a minute for the whole page to load up
    Noel-theknurl
    New Braunfels, TX
    Ed Cook AF1 ed@af1racing.com
    AF1 Racing Online Store
    apriliaforum expert Kid A's Avatar
    Apr 2006
    LI ,ogacihC
    in case you're interested in component weights & removing some weight form your bike:
    http://spreadsheets.google.com/pub?k...bA&output=html
    07 Aprilia Fluo Red RSVR ('factorized' + 1060, Smaltmoto, ETI fuel cell & other $$ stuff)
    08 KTM 690 SMC
    00 Yamaha YZ125
    Trying to remove weight from your Aprilia?
    click here:
