If you put iot back together it needs to be about 0.5mm, but if your just checking the engine before doing a rebuild or just a maintanance check and its more than 1mm you have to do something about it.
The steel plates got a notch on it, they need to be ofsed 120 degreas from each other.
Clunks downshifting can be from a number of things, but the most common one i come accross is the clutch not being adjusted properly or a problem with the plates/basket so it does not fully disengage wen pulling the lever in.
