i thought i should add a bit of a local connection for you rather than the normal fat kid on a cupcake metafor.
I could just send the straight one for $80 and save you some shipping!
Seriously though, if you are after a pair I'd do the same.
Ohlin Shock sold!
I'm looking for a complete subframe and under tray, with or without fairing / plastics.
PMd' you.
A quick update on what is remaining. I'm happy to consider any reasonable offer.
All the body work is gone except for the tail panels complete with pod and clear indicators. Good condition.
Screen.
Footpegs. Left side OK except for a little scraping on the tip from low cornering. Right side bracket bent. Both heel guards OK.
Upper and lower triples.
Evo air box kit and filter.
Left switch block in good condition.
Some assorted electrical bits and pieces.
pm sent
Tail panels, pod and indicators sold.
I've just decided to sell the entire OEM exhaust system including the Akra slip ons and straps. As you can see in the photo the left side is OK. The right side can and link pipe are damaged. I'll try and get some pics of everything up tonight. I'll include some prices with the pics as I've not thought that far ahead yet but I'm open to offers. I'll offer it as one lot initially and go from there. For Aus members I note there is a pair of Akra slip ons on ebay at the moment with damage to the left one!
$360 for the entire system, including all pipes, cans, c/f straps, springs and heat shield. I'll be keeping the bolts that attach the straps to the hangers. Shipping not included.
i've listed the exhaust system on ebay at a lower reserve.
http://www.ebay.com.au/itm/Aprilia-A...#ht_500wt_1413
Also forgot to mention that I still have the front radial Brembo calipers.
All the undamaged items that remain. Make an offer. Under pressure from the CFO to clean up the garage.
Pair of Brembo front radial calipers.
OEM exhaust system minus mufflers.
Screen.
Left side foot peg.
Left side switch block.
HT coil (new).
Plastic rear hugger.
Oil tank.
Rear chain guard.
Upper triple for Ohlins.
Sprocket carrier (I will include either one of the sprockets below at no extra cost)
Black 40 tooth 525 rear sprocket. It looks like it had not been on the bike for long. Hardly any sign of wear.
I also have 41 tooth 520 Alumalite racing rear sprocket that have only done one practise and race.
The lower triples are straight but one stop has been sheared off.
is 40 the standard for the rear? if so i'll shoot you an offer on that sprocket.
