Emil
If I switch the motor off using the red switch on the right handlebar, the motor stops but the dash indicators are still on, but I do not hear the fuel pump running. Same as when I stall the motor. However, when I then turn the ignition key off and then on, I hear the fuel pump prime for a couple of seconds then stop. So when your bike stops and you turn the key and on again, you should hear the fuel pump prime. Does it?
