2008 HAULMARK 7X14 V NOSE LOW HAULER TRAILER, HOLDS ANY TWO BIKES PERFECTLY....HARLEY FULL DRESSERS TO RACE BIKES, IN ADDITION TO TOOL BOXES, STANDS,GENERATOR, ETC...TON'S OF ROOM
DUAL TORSION RUBBER AXLES, EXTERIOR WALLS ARE SMOOTH NO RIVOTS/SREWS, INTERIOR WALLS ARE FULLY FINISHED IN WHITE PANELS, CUSTOM WOOD WORK BENCH, RUBBER INTERIOR FLOORING,VERY CLEAN, NEW SPARE TIRES, 4 TIER REMOVABLE SHELF, 2-ELECTRIC PLUG JUNCTION BOXES, EXTERIOR POWER PLUG. DIAMOND PLATE STONE GUARD AND INTERIOR FLOOR RAMP. THIS IS AVERY NICE CLEAN TRAILER, GARAGE KEPT DURING THE SUMMER, IT DOES HAVE A FEW IMPERFECTION BUT YOU WILL NOT BE DISAPPOINTED...THIS TRAILER COST $8000.WHEN NEW!
THIS IS THE RIGHT ONE.... BE THE ENVY TO ANY TRAILER OWNER...TOW BALL AND TONGUE INCLUDED...JUST BRING YOUR TRUCK TO TOW IT AWAY!
ONCE PAID FOR I CAN HELP WITH DELIVERY IF NECESSARY.
Additional Features
Tires: ST205/75R15 C rated GOODYEAR TIRES
V-nose front - Great looks and best mileage
Low platform - Easy loading and unloading
Low profile - Easily fits in most garages
Screwless exterior and custom graphics - Helps you stand out in a crowd
Fully finished interior - White vinyl on ceiling and walls - Bright and easy to clean
Polished aluminum front and rear corners - Better appearance
Polished aluminum lower exterior sides - Custom look
8 D-ring floor and wall tie downs - Prevents bikes from moving
Removable wheel chocks - Increases cargo flexibility
Drop-down stabilizer jack - Helps stabilize trailer during loading
Rubber ride suspension - Premium ride quality
Radial tires - Improves ride
12v Dome Light with Wall Switch Haulmark Sidewall Vents (2)
32" x 54" Side Entry Door - Bar/Flush Lock 24" ATP Stoneguard Removable Wheel Chock 5000 lb. D-Rings with Welded Plate 3/4" Black NUDO® Flooring Chrome Nose .030 Prefinished Aluminum Exterior Custom Low Hauler Graphics Screwless & Seamless Sidewalls
12v Dome Light with Wall Switch • Haulmark Sidewall Vents (2) • 32" x 54" Side Entry Door with Bar/Flush Lock
24" ATP Stoneguard
8) 5000 lb. D-Rings with welded plate (also shown Black NUDO® Flooring)
Chrome Rear Corners & Rear Header
White Vinyl Sidewall & Ceiling Liner
ATP Covered Ramp Extension
ATP Covered Rear Ramp Door
32" Recessed Beavertail
.080 Ramp Door Hinge Cover 18) Drop Down Stabilizer Jacks
GOODYEAR 15" Radial Tires
CHROME ALLOY Wheels & ABS Center Caps
Torflex® Rubber Ride Suspension
22) 2-Tone Polished Aluminum Bottom Panels
http://www.haulmark.com/userfiles/HM...er_2011(3).pdf
Here's the craigslist ad
http://miami.craigslist.org/brw/rvs/2911821514.html
Send me a PM and I'll forward all the photos...If a forum members buys it a few very nice bonus items will be included!
GPC
