Results 1 to 4 of 4
Thread: 2001 aprilia rs50 been in storage
    Mar 2012
    ma
    what should you do to get rs 50 running if it been sitting for 5 years any tip would be helpful
    Sep 2011
    warrington uk
    check fuel isnt dodgy, most likely is after sitting for so long
    drain fuel through fuel tap
    put some fresh fuel in and top up oil, coolant ect
    clean carb
    stick a new sprak plug in there or clean up the one thats in it with a fine wire brush
    try bump start it
    charge battery
    good luck, iv found that most bikes that worked fine before and have been sat for yrs start without a problem but the above tips wud definatly help
    Engine Always Screaming!
    apriliaforum expert mumbl3s's Avatar
    Jan 2012
    kent, uk
    Quote Originally Posted by chrism15 View Post
    clean carb
    try bump start it
    charge battery
    + maybe put a bit of pre-mix in the spark plug hole just to help with lubrication of the piston
    Warming the world 2 strokes at a time.
    <- *check out the BMX with a 50cc engine *
    2008 rs50 - SOLD
    Dellorto - PHBG 21mm tuning carb
    Arrow Exhaust - not sure which one
    Doppler - D50B0 Endurance crankshaft
    Italkit - 74cc cylinder kit
    Malossi - 0.40m reeds
    Malossi - upgraded clutch springs
    2006 gz125 - Winter Bike
    No Upgrades
    1981 CB250N (30BHP Version) - In Restoration
    Going to be a Cafe Racer with a modern twist!
    Oct 2012
    florida
    clean the carb
