Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 31
Thread: Rs 50 rear tyre ?
    apriliaforum prov-nov Kentiish Lad's Avatar
    Jan 2012
    United Kingdom.
    i went for the 130 rear because from past experience of getting too low and nearly coming off the limit of the tyre. Now im no where near the edge of the tyre when getting low.
    apriliaforum expert Glen1990's Avatar
    Barrow in furness
    you fitted a 130 on an rs 50? i didnt even know it would fit how did it change the speed?
    Aprilia rs 50 2000
    Top performance Pink 75cc
    Doppler Endurance crankshaft
    Arrow racing exhaust with carbon endcan
    Dellorto 21mm carb(92 main jet)
    Stock air box modded
    Top performance Cdi
    Malossi reed block 0.30mm
    Conti race clutch kit
    14/47 Gearing
    Mono rear
    Michelin pilot sport tyres
    Rs 125 front master cyilinder
    Malossi upgraded clutch springs
    Rs 125 Headlight
    UPGRADES to come
    24mm mikuni flatside carb
    Double bubble screen
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    Full respray and frame polish
    Doppler air rear shock
    apriliaforum expert ryanperkins's Avatar
    Dec 2011
    kettering
    Quote Originally Posted by Glen1990 View Post
    ive used michelin pilot sporty's in the rain and over winter gotta say its in the wet they out handled my other tyres i never sliped or got them to slip on my old bike (same size tyres) oh and you can get a pair of them for £109 with 48hour post free cheap as hell
    :O where, and fancy giving me a link?
    as my new rs needs a front tire and the rear aint far off... and it needs them for an m.o.t :L
    tahhh
    what do you think off mine? comments please!!
    Barrow in furness
    http://www.thevisorshop.com/acatalog/michelin.html go down to the cbr 125 tyres that set they are the same size btw =]
    Aprilia rs 50 2000
    Top performance Cdi
    14/47 Gearing
    Mono rear
    Rs 125 Headlight
    UPGRADES to come
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    Jan 2012
    United Kingdom.
    Yep fitted easy, Give the tyre a more of curve on the edges so no need to worry about going off the tyre when getting low. Speed is still the same.
    Sep 2011
    warrington uk
    wide tyres look the bollox but thin tyres you can get real low on
    Engine Always Screaming!
    apriliaforum Junkie ToraTora's Avatar
    Apr 2010
    San Francisco
    Cool Expanding your dimensions
    The stock tire size on the back of my 05 GPR is a 130 and I'm currently running a 140 back there because I wanted to sport the BT003 RS Bridgestones. They are amazing multi compound tires (harder in the middle softer on the edges). These tires added a significant amount of stability to the bike, and with the recent Ohlins shock upgrade the bike tracks amazingly well.
    Anyway I've written up some tire info for the GPR up on Bats--much of the info transfers well to the RS. For stock tire sizes the Savas have a lot to offer.
    Nov 2005
    Quote Originally Posted by chrism15 View Post
    On stock size Michelin Pilot's you can, some other tires are not so nice for taking flat corners... Wider tire isnt gonna change that as the tire deforms on the narrow rim we got, (tire buldges in center as it gets sqeezed by the narrow rim) in some cases i feel like the bike falls inthe corner than wen you tip it as there 130 wide (stock is 110 wide)
    Got some Battlax also on my other bike, they where really nice also in the corners because of the softer compound on the sides, and low wear because of the harder compound in the middle, what i seruosly didnt like about them was driving in the wet though, even a little rain was enough for the bike to start to slide.
    Apr 2010
    San Francisco
    I've had awesome traction with the BT003 RS in the wet. The make a lot of different Battlax tires, and it may be your suspension set up too. So many variables can account or a bike being good in the dry and horrible in the wet.
    Sep 2011
    warrington uk
    Quote Originally Posted by RS_Patrick View Post
    iv got battlax"s on my suzuki, i agree with what you"v put - already in the rain and lightly held the rear brake and can feel it slide however many metres on back.....
    other than that i think nice tyres
    Apr 2010
    San Francisco
    Cool Unequal Creation
    Which BT's are you running? Because there are many different versions, and it would be nice to know which ones are having difficulty in the wet. For instance the BT45 is nothing like the BT016 or BT003 tires. I also believe that suspension plays a big part. When the MotoGP boys set their bikes up for a wet track they soften up the suspension in addition to changing the tires. They also program the engine management to deal with the wet (less power). We can effectively do the same stuff with our bikes by throttle control. Throttle control has a great effect over how the suspension reacts.
    On the Mito I'm currently running the BT016. I bought these before I found the SP wheels. The stock rear is a 4x17, and the SP is a 3.5x17, so the 150 tire I have on the rear which had a nice profile on the stock wheel has a really round profile on the SP wheel. I was thinking to go for BT003 RS for the next go around however I'm finding the BT003 RS on the GPR to wear quickly on the rear--and by that I mean develop a flat spot from the in City riding. =8<>
    Nov 2005
    BT45 i think, they got a bit more thread like yours, also had some racing tires for in the wet, but dont recall wich Battlax they where, but running them on dry road destroys them so i doidnt have them to long.
    Pilot's got loads of grip and are nice and round and really feel like there glued to the road in the corners, i dare to run them much flatter in the corners than any other tire i had, there still ok in the wet as long as its not a downpoor.
  13. #28
    Apr 2010
    San Francisco
    Cool These are not your gram-ma's tires
    The BT45 is an entry level bias ply, and doesn't come close to the BT003RS or BT016--which are about as high end as Bridgestone makes.
    BATTLAX BT-45 is a touring type tire offered in both H and V rated speed symbols. BATTLAX BT-45 gives all-round street performance, with the emphasis on riding comfort, long mileage, wet performance, all designed by the latest tire developing technologies of Bridgestone. With the comprehensive tire sizes, BATTLAX BT-45 replace BATTLAX BT-35 and BT-17V.
    BT-003RS
    Specially street-tuned sport tire derived from latest racing tire BT-003. Its Ultimate Grip Performance derived from MotoGP technology provides riders sporty riding enjoyment with confident grip on streets and dry-condition circuits.
    TARGET PERFORMANCE
    Street Sport Tire with Ultimate Grip Performance is derived from MotoGP technology.
    Designed for Sporty Riding enjoyment with confident grip on streets and dry-condition circuits.
    Specially street-turned tire developed from our latest racing tire BT-003 which has achieved many victories in production-class races (600cc-1000cc).
    BT-003RS is the successor to BT-002RS and BT-090 and covers various engine sizes and models (from middle sport class to super sport class).
    The 3LC (3 Layer Compound) and 5LC (5 Layer Compound) provide regular wear and the optimized pattern design provides longer wear life than ex-models: BT-002RS/BT-090.
    TECHNICAL FEATURES
    New Generation Technology for Motorcycles : 3LC+Ultraction Compound
    “Ultraction Compound” was developed to achieve the best possible grip performance on public roads and dry circuits. All compounds in BT-003RS are superior in road-holding grip, especially this newly developed “Ultraction Compound” used in the shoulder part of the tread which improves road-holding grip spectacularly.
    ☆ “Ultraction Compound” is adopted for Super Sport size only.
    The 3LC (3 Layer Compound) created from MotoGP pure racing technology also helps optimize the performance of every compound by putting the right compound in the right part of the tread.
  14. #29
    Nov 2005
    I used to work at a Bridstone dealer, otherwise i would not have bought those tires.
    BT39SS Mini or GP3 (track only (Slick/Wet, i "melted" my wets by runing them in the dry ) might be something you want to look at the next time you need some tires.
  15. #30
    Apr 2010
    San Francisco
    Thanks, but I ride street so no slick tire purchases for me.
