Page 8 of 11 FirstFirst ... 678910 ... LastLast
Results 106 to 120 of 165
Thread: Snugg's '09 SR70 PFI Commuter
  1. #106
    Moderator (ADSUM) Grenadiers's Avatar
    Sep 2008
    Nice weather AT LAST! Winnipeg, MB
    This is starting to sound like either a "Transmission implosion" somewhere around the Variator, or you hit something under your bike in the area of the Starter...
    Either way, I hope that you get it all sorted out and are back on the road again soon!
    Anger is an ugly Mistress…
    06 SR50 (Morini)/AIRSAL 70CC BBK/NGK BR9EIX/My Top Speed-117KPH (GPS)!!
    Rear Rack & Top Case/Buzzetti Side stand/Aprilia Racing Shock W/STR8 65mmRiser/HGT Stretch Kit
    HGT PFI Kit/Malossi MHR Team II Pipe/All Polished Water Pump
    Black HGT Gen 3 Fuel Regulator/Stebel Magnum Horn/Glowshift Elite Gauge
    BING 26mm TBA/BGM Pro Reed Block & Pod Filter
    Polished Aluminum Varo W/Kick start & Pod Filter/HEL Brake Lines
    HGT Red Brake Levers/LED bulbs/BGM LED Tail Light
    Malossi Delta Clutch w/Blue springs/Red Contra spring & TC/MHR Full Circle Crank
    Malossi 15/40 Primary Gears & Multivar w/4.4gr Dr. Pulley Sliders/Kevlar Belt
    Michelin Pilot Sport 140/60 Rear tire w/Dyna Beads & TPMS Sensor
  2. #107
    Banned Snugg's Avatar
    Aug 2007
    Aurora, CO
    I was having problems with my kevlar belt hitting my starter motor bendix. Didn't know if the cause was my V2008 or the actual belt. I believe its more of the belt though. Its longer and thicker than any others.
    while at full transition the top of the belt rides just above the pulley and therefore hits the bendix.
    in order to fix it, I had to go to the stock variator and stock belt.
  3. #108
    apriliaforum expert NoNameForEver's Avatar
    Sep 2008
    Northern Europe
    Is this ominous news for anyone that goes to 86cc, and have to use the kevlar belt? The first version of your beast did this to the stock belt.. Anyways, are you any closer to getting the CVT setting from dropping of at WOT?
    Glyptocephalus cynoglossus lover
    Quest for no 3D glasses
  4. #109
    Aug 2007
    Aurora, CO
    Now that I'm using my stock variator, stock belt and 5.1g rollers with the ZX-R, the RPM does not drop. Acts just like a Ditech. 8200 RPM at WOT, never drops and at full transition, it then starts to rise.
  5. #110
    Sep 2008
    Northern Europe
    So now you have PFI commuter the way you wanted it? If so, congratulations.
  6. #111
    Aug 2007
    Aurora, CO
    I'm still trying to figure out why that setup on my scooter was failing. I've been in contact with HGT and it seems to be something related to only my scooter and not the 86cc builds. Which has me stumped.
    Rich would never send anythimg out that does the same thing. So those going to 86cc don't worry
    For now I'm riding with my stealth setup and will play with more setups when I get the replacement parts delivered.
    But I'm really loving this current build.
  7. #112
    apriliaforum expert Rosscofat's Avatar
    Vancouver BC
    so you changed belt, Variator, Rollers and Exhaust?
    are you still able to reach the same speeds?
  8. #113
    Aug 2007
    Aurora, CO
    Same rollers as I was using before, so those didn't change.
    Haven't tried for top speed but yes reaching same speeds in the same time.
    I can easily cruise at 55-57
  9. #114
    Vancouver BC
    Good to hear. are you Pre mixing the same amount as you did with the other kit you ran?
  10. #115
    Vancouver BC
    Snugg your inbox is fulll
  11. #116
    Aug 2007
    Aurora, CO
    Quote Originally Posted by Rosscofat View Post
    Yeah currently using 35:1
    Fixed, thanks for the heads up
  12. #117
    apriliaforum Junkie Molino's Avatar
    Nov 2009
    .Boston
    Quote Originally Posted by Snugg View Post
    It's because your engine was manufactured by Piaggio and not Morini :P. I'm sorry, that was mean, but I just had to xD. Good luck getting to the bottom of it. Once you start doing all kinds of heavy mods like these it gets to be a pita figuring out which part isn't working right.
    2007 Morini SR50
    Malossi 70cc BBK , LeoVince ZX-R & 7.0g Rollers,
    BGM LED Taillight, Ferodo Platinum Brake Pads,
    Marchald Pro Porting Pod Airfilter, NGK ZMR7AP,
    MHR VL12 Reeds, Malossi Galfer Front Rotor,
    Polini Kevlar Trans Belt, Royal Purple 75w80 Gear Oil,
    Kobalt Water Trap, Amsoil Saber 100:1 Full Synth 2t Oil,
    STR8 Carbo Look Shock Riser, Buzzetti Sidestand,
    Avon Viper Stryke Rear 140/60, Stainless Steel HEL Brake Lines
    Top Speed: +-65mph
  13. #118
    Aug 2007
    Aurora, CO
    heh, I do miss my old Morini.
    But yes you have a good point. This is the reason I went to a mild build now. I absolutely love the way this thing is running now.
  14. #119
    Aug 2007
    Aurora, CO
    Just turned 450 miles today on the new Sport setup. !!!
  15. #120
    Vancouver BC
    Nice... when we going to see some vids.. even if you do not like the wind noise.. hehe i would lovvvee to see the pick up!!
