OK, Battery is good... It could be Pin Tension (HG may comment on that part... and others).
Anger is an ugly Mistress…
Michelin Pilot Sport 140/60 Rear tire w/Dyna Beads & TPMS SensorMalossi 15/40 Primary Gears & Multivar w/4.4gr Dr. Pulley Sliders/Kevlar Belt
See if you can borrow his ECU and give it a try... If there is no codes, then...
It will work..
Glyptocephalus cynoglossus lover
Quest for no 3D glasses
I was thinking, is there anything else i should check regarding that code 9 ?
To recap: I disconnected the wires from the ECU, injector relay, and air and fuel injector and checked the wire connection with my tester, everything was perfect, tried with another injection relay, air/fuel injector and stator, still same fault.
Of cause with every thing i swapped i let the codes reset, but it keeps coming back.
What can set a code 9 without turning the engine on, it must be some selftest the ECU is doing when you turn the key to ON.
Can anybody shed some light on that, maybe give me a few ideas to what can cause that fault ?
Model 2001, 15000k's, I think the safe bet is on the TPS sensor... Been a lot of twisting and wear on that sensor.. So this is the best option.... In my opinion, that is..![]()
200? WOW. awesome.
Had a chance to try with that other ECU today, and code 9 remains, it must be the wiring on the machine thats something wrong with ?
What causes the ECU 9 error?
2010 SR 50 R Factory (max speed so far downhill/tucked: 70mph indicated)
- De-restricted (2.8.0)
- Leo Vince ZXR pipe
- NGK ZMR7AP (gap: 0.035")
- Malossi Multivar 2000 w/7.2g Rollers
- White contrast spring
- Red clutch springs
- Malossi TC
- Malossi VL13
- Harbor Freight Water Trap
- Stage 6 gear kit 13/39
- HGT Fuel Regulator @ ~118psi
Took the Ditech apart today because i had to move it to a another frame so it will be street legal again.
The wiring was faling apart, so a new one has been ordered, i hope that will solve that pesky error 9.
