Page 14 of 14 FirstFirst ... 4121314
Results 196 to 198 of 198
Thread: What you get for 200 USD.
  1. #196
    Mar 2012
    Nordjylland, Denmark.
    New gaskets and o-rings fitted, and it fired up on the first try and was rock solid in idle, going to take a testdrive, and will then check the sparkplug, and if everything is good change it to a ZMR7AP.
  2. #197
    Sep 2008
    Nice weather AT LAST! Winnipeg, MB
    Quote Originally Posted by Rejected View Post
    Glad to hear!!
    When you got the plug out, run another compression test just to make sure that all is good and tight! Then again a day or so later and compare numbers. A drop of more then 5 to 10 PSI could be an indication of another issue coming up...
    "An once of prevention is worth a pound of cure!!"
    Anger is an ugly Mistress…
  3. #198
    Mar 2012
    Quote Originally Posted by Grenadiers View Post
    Glad to hear!!
    Took it out for a long drive yesterday, something like make or break trip and everything was fine, checked compression today and its the same as yesterday, so everything should be good.
    I'm thinking about adding a watertrap, just to make it a bit better.
