If you remove the air box/ filter and look down the pipe that connects from it to the carb there should be a snorkle that reduces down the size off the pipe.
Full UK Bike licence!!
Suzuki DRZ400
Aprilia MX125 2005 40Mph crash now Cat C
Renthal bars!
Full Arrow exhaust system
16/45 final drive
SBS Brake pads! (Highly recommend!!)
Aprilia SR50R 2005
Leo Vince TT
Malossi X-Drive Special belt
I was getting...(SR50)(GPS)
Flat: 54mph (no tuck, light wind)
Downhill: 57mph (no tuck, no wind)
Uphill: 44mph on what i would consider a good hill (No tuck, no wind)
At the moment im getting...(MX125)(Speed'o speed's) 16/45 16/43
Flat: 82.7mph, 6th gear... No tuck/No wind 87.2mph
Downhill: 86.2mph sat down but not on the tank... 91mph
Uphill: 73.6pmh, Steep hill, 5th gear pulling! 77.3mph
Can you tell me what snorkle you are talking about because as far as i can tell nothing had been changed by the previous owner so i wonder why it had a 78 jet. Do you think that considering my bike did 50mph with the standard exhaust and 78 jet, i should get an even bigger one like an 84 hence the leovince zx i put on?
There is a snorkle inserted into the airbox, it reduces the bore off the pipe and there for the amount air that can flow through, With this removed you'd be looking at about a 70-80 main jet with it in around 55-60...
With the pipe question, No by the sound the bike needs re-jetting and the needle clip moved as a stock de-restricted bike should have a 50-55 main jet not 78
What does your plug look like? Black-white-light brown-wet-dry??
Suzuki DRZ400
Renthal bars!
16/45 final drive
Aprilia SR50R 2005
Leo Vince TT
