Results 1 to 12 of 12
Thread: 2012 edition of not starting
    apriliaforum expert Stanleybobly's Avatar
    Jun 2010
    Netherlands - Türkiye
    Ok, I'd admit. It runned last year 10k km, without any major problems
    just a tiny o-ring on the injector blewed/melted away .
    this year, after not starting the bike in 3 months orso , the bike won't pressurize the fuel pump
    I just hear a little & very short chizzling that's it.
    it did a few weaks ago the same, after 20 times ignition on of it did the normal chizzling sound of the pump and it started.
    I pulled everything out
    maybe it's not wiring in the fuelpump
    it was ok, measurements reads out the wire is alive. (or not)
    12v on the pumps give a spin, not noisy thoo... (or should I hear a vacuumcleaner )
    the boot of wiring is looking like this
    soft & spongy, ethanol is doing it's job, that's why Caponord is not compatible with E10 fuel
    the o-ring a bit leaky on the pic. so need the swap that one too, with a Viton ring
    the corrugated pipe looked fine. filter is 8k km old.
    I'll going to check the injectors.....
    sold: "01 Caponord |Flame Red|, Modlist done: Honda CBR600 RR Mosfet (FH008) Rectifier Mod, Brown Connector Mod
    now: "04 Caponord |Rally Raid| FH016 Mosfet R/R | GPR Titanium Exhaust|
    01 Futura [infinity blue]
    Caponord Stanleybobly style loomed MOSFET Rectifiers & Fuelline Kit FS
    Jun 2010
    update :
    found the cause of not priming the fuel pump
    it was this little bastard
    it works, but sometimes it don't
    so have a spare in your bike, this thing is unreliable
    although it says MADE IN JAPAN
    apriliaforum expert the_toe_cutter's Avatar
    Ireland
    Good find Stanley! Find any affordable replacement online anyhwere? I must buy a spare to carry!
    Brum Brum
    Jun 2010
    the relay is exactly the same as on my Aprilia SR50 scooter
    your scooter shop has it also.
    fleabeey 1
    fleabuy 2
    fleubeay 3
    GENUINE HONDA PART
    apriliaforum expert chrisonord's Avatar
    Jun 2007
    THE SHITTISH ISLES
    I had a similar problem with the relay on mine too, went and got one from a breakers near me, but have just got a spare one from ebay, as you never knowhow long it could last
    Chris.
    Scottsdale, AZ
    Quote Originally Posted by Stanleybobly View Post
    Right. I was going to tell you that, but you've already discovered it. 198 different Honda models use that relay, so there's a good chance a Honda dealer might have it on the shelf - part # 38501-GN2-014.
    Stu
    apriliaforum expert JohnG.'s Avatar
    Sep 2006
    Mackay Qld Australia
    ...and for those still looking for it...
    BTW,Middle relays are the same ?
    & what does the 'diode block' do?
    JohnG.
    '02 Capo..."take the road less travelled..."
    http://www.youtube.com/watch?v=j7XDAfD6E8o
    Sep 2006
    Quote Originally Posted by Stu_O View Post
    Stu
    Stu,Yup,
    http://www.ebay.co.uk/itm/HONDA-TRX-...item45f914bd0b
    Stanley,
    Great info,thx
    JohnG.
    apriliaforum Member BigAdam's Avatar
    Melbourne
    STU-every time I see your posts I think you are in fact Kevin Costner, just hiding under sunglasses
    Sep 2006
    A quick google reveals...
    ORIGINAL PART NUMBERS:
    Aprilia: 8224462, formerly 8212469 just checked & edited,the rest must be accurate being from the 'net
    BSV: 38501-GN2-003
    Cagiva: Y00-FA0-295 Y00-FA1-354
    Honda: 38501-GN2-003/014 (although 38501-GN2-014 seems to work)
    Kymco: 38501-GN2-003 001-60-003 38501-GW2-900 001-69-208
    Peugeot: 712956 724154 712645
    Suzuki: 31800-29C00/03A00 25E00/16A10
    Also Kawasaki 1100 & 750 and most MTD,Bolens etc ride-on mowers...used as a general lights/EFI/fuel pump/starter relay
    JohnG.
    Scottsdale, AZ
    Quote Originally Posted by JohnG. View Post
    ...& what does the 'diode block' do?
    It's part of the starting safety system involving the clutch lever switch, sidestand switch, neutral switch.
    Scottsdale, AZ
    Quote Originally Posted by BigAdam View Post
    Darn! Now I'll need to use a different screen name and picture.
    Kevin
