Results 1 to 15 of 21
Thread: Danmoto cans
    apriliaforum prov-nov leenineplus's Avatar
    Nov 2011
    Lancashire
    Danmoto cans
    Help, just got a set of gp cans and the tubes will not go into the end cans, any suggestions please?
    apriliaforum Junkie srastoder's Avatar
    Aug 2010
    Bowling Green, KY
    Quote Originally Posted by leenineplus View Post
    When I got my CF cans they were hard to get in also. They were fine when I installed the link pipe to the can. Dan Moto link pipes fit inside the factory exhaust pipes unlike my Leo that fit over them. My Dan Moto cans were a tight fit too. I had to send down the inside of the factory and outside of the link pipe just a little and then I used just a little of WD40 to get it to slide in about 1 1/4" or so. It worked great, but when I went to take them off, the right side was a bitch. I will send them down just a little more before I put them on next time for a track day. Hopefuly this will help you.
    '05 Aprilia RSVR Factory
    '09 Aprilia RSVR
    '01 RSV Mille
    Canyon Lake, TX USA.
    Leave link pipe in freezer for 45 minutes, heat female end of can with propane torch then add wd40, a little thermal expansion and contraction will get the job done. Back in the dark ages prior to Akro pipes this was simply how most aftermarket pipes were installed. A nice flap wheel on a die grinder will take down high spots on both tubes and this may help a lot too. Make sure to VERY carefully clean any part an abrasive is used on, since few are made with non-embedding abrasives like Garnett.
    Micah Shoemaker
    699 W. San Antonio
    New Braunfels, TX 78130
    830-626-3966
    micah@af1racing.com
    Jul 2011
    Flo Rida
    I have to say mine fit up snug, but I didn't have to use too much effort. The fact that you say they plain just "will not go into" cautions me you might have the wrong link pipes.
    To help clarify:
    When you say the don't go into, is that implying a tight-fit / impossible fit due to size/diameter issue), or an alignment issue when trying to mount everything?
    Have you tried rotating the link pipe to illicit optional angles?
    Using only the link pipes, do they fit into your bike's pipes like srastoder pointed out?
    Can you post a few pics?
    Dec 2011
    el paso, texas
    I put the link pipes onto the header and then just worked the Cans on. When i first got the exhaust i thought they sent me the wrong link pipes, but after about a min or 2 they went right on.
    Nov 2011
    Lancashire
    Fitted eventually, only took me five bloody hours. I will test tomorrow, but yes they are LOUD.
    Nov 2011
    Lancashire
    Just been into the attick, when I bought the bike it had Akro's on and there was a collector box which I presume must be the standard system. I guess the collector box on mine is for the Akro systems collector box!!
    No wonder they wouldnt go on so easily.
    My Akro cans must be part of a full system then. I suppose I should strip it all down and start again by putting the original collector box on. Mmmmm.
    Pics of each please. If you have the Akro headers they are a little better than the stock headers for the non EVO series, if you have EVO6 series headers by all means use them as they are the best I have ever tested, and that includes a lot of pipes.
    Micah
    Micah Shoemaker
    699 W. San Antonio
    830-626-3966
    micah@af1racing.com
    Nov 2011
    Lancashire
    Here she is.Name:  422377_357005974333227_100000714814674_1127792_1510200978_n.jpg
    Nov 2011
    Lancashire
    Ridiculously LOUD.
    Dec 2011
    el paso, texas
    Yes, yes it is.
    Jun 2006
    Columbus, GA
    Oh, Wow!
    __________________
    ____@FoxFader_____
    Current Swag - '01 Futura in Silver, Acumen DGVPainted W-screenPazzo Knock-offs.
    Jesus, family, me. Psalm 121 - Red Pill Mille Clip - Delkevic Sound Clip
    Past Swags: 09 RSV 1000R, 06 GSXR 1000 SF, 02 Bandit 1200 N, 03 RSV 1000, 05 Katana 600, 98 VLX 600, 00 GSXR 750, 01 Futura 1000, 02 Bandit 1200S, 83 V65 Magna, 91 Nighthawk 750, 9? 700 Honda, 93 GSXR 750wp, 91 Katana 600, 78 KZ400, 82 CB450 Custom
    HF152, 10-26954
    HF564,
    __________________
    __________________
    Jul 2011
    Flo Rida
    Visualize this... it'd be interesting to somehow get rid of the mid-pipes altogether and have those GP's much lower.
    apriliaforum expert Mille Racer 69's Avatar
    Nov 2007
    Redding, California ~2007 RSVR 1000 Factory ~Nathan
    dayum!!!1!!111!!one!!1!!!
    that looks like it would sound like a straight pipe
    I core pipes - correctly
    PM if interested
    Twisties ride - YouTube video
    Cored pipes rideby soundcheck
    Dec 2011
    el paso, texas
    Quote Originally Posted by TimeBandit View Post
    like cut out about 4" of the connecting pipe... i am sure a good muffler shop could make something work or maybe stretch the bottom of the can to fit over the header pipe.
