Page 13 of 39 FirstFirst ... 3111213141523 ... LastLast
Results 181 to 195 of 573
Thread: Proposed Colorado “SR50 Get together/Rally” approx. 3 to 15 Jun 2012!
  1. #181
    Moderator (ADSUM) Grenadiers's Avatar
    Sep 2008
    Nice weather AT LAST! Winnipeg, MB
    OK, here are the pics of my test ride with my modified trailer with the bike on it.
    The trip was done in 2 parts. A short haul trip (about 20 minutes), and then if all looked good and securre, a long haul trip (about 90 minutes). For the first trip, I stopped several times to check the tie-downs, anchors and the wheel hubs (brought my infrared thermometer). All straps and anchors were great and tight. Temp readings on one of the hubs had me look at the tire pressure and sure enough, it was low, like half the other sides tire!!
    Here is the ramp I made... 2X10X70 pressure treated board.
    Here I'm stowing the Ramp after loading the bike. The ramp is secured to the deck with 4" Pins.
    Here is a view of the front angle iron that I had to grind away a bit of to protect the bikes nose. I also added some pipe insulation for added protection... For the actual trip, the pipe insulation will be tapped down.
    Here I just "Installed" the handle bar straps I got on eBay. One of my better purchases!! Notice the new seat? Thanks to William the Third, I replaced my red seat with black.... MUCH better!!
    Here is one of the straps installed...
    Here is the rear strap and a closer view of the ramp secured on the deck...
    More to come!!
    Anger is an ugly Mistress
    06 SR50 (Morini)/AIRSAL 70CC BBK/NGK BR9EIX/My Top Speed-117KPH (GPS)!!
    Rear Rack & Top Case/Buzzetti Side stand/Aprilia Racing Shock W/STR8 65mmRiser/HGT Stretch Kit
    HGT PFI Kit/Malossi MHR Team II Pipe/All Polished Water Pump
    Black HGT Gen 3 Fuel Regulator/Stebel Magnum Horn/Glowshift Elite Gauge
    BING 26mm TBA/BGM Pro Reed Block & Pod Filter
    Polished Aluminum Varo W/Kick start & Pod Filter/HEL Brake Lines
    HGT Red Brake Levers/LED bulbs/BGM LED Tail Light
    Malossi Delta Clutch w/Blue springs/Red Contra spring & TC/MHR Full Circle Crank
    Malossi 15/40 Primary Gears & Multivar w/4.4gr Dr. Pulley Sliders/Kevlar Belt
    Michelin Pilot Sport 140/60 Rear tire w/Dyna Beads & TPMS Sensor
  2. #182
    Sep 2008
    More pics!!!
    Here is a shot of the trailer hitch setup... The larger cable on the right in the 2nd photo secures the bike to the trailer.
    After the ride and clean up of the trailer...
    Some closeups of the LED running lights I installed.
    OK, that's it for now... Next photos will be from the trip!
  3. #183
    apriliaforum Junkie Louder North's Avatar
    Ottawa, ON Canada
    Absolutely awesome! I don't think I've ever seen a better, purpose-built trailer. You're gonna have to paint 'Tempus Fugit' on the side! (along with Colorado or bust!)
    2007 SR 50 Factory Ditech (Morini) 9000 kms
    Buzzetti side stand 03/18/12
    PIAA 'Slim Line' Sports Horn 05/21/2012
    Porter Cable water trap 06/19/12
    ECU completely derestricted ver 2.8.0 (YES! Thanks HGT 08/10/12)
    LV ZX-R 09/10/12
    Motul Scooter Power 2T oil (100% synthetic)
    NGK ZMR7AP spark plug, indexed, gapped to .030
    Malossi Multivar 2000 w. 7 gm rollers, Malossi Special Belt, White contrast spring @ 8000 km 11/12/12
    8mm Mirror Riser Extender 05/12/2013
    Michelin Power Pure tires @ 9000 km 05/18/2013
    90 kph on slight down hill
    Also in the garage: 1987 BMW R80
  4. #184
    Sep 2008
    Thanks!!
    The trailer actually started out very different when I purchased it. But I needed to "tweak" it a bit to be used as a Toy Hauler. My goal was to convert it so that I could switch between a Toy Hauler and regular trailer. The top comes off fairly easy even for one person.
Name:	My trailer 4 in 1 01.jpg
    I still have to paint it, but I need nicer weather in order to finish it. The other goal is to rig the Wheel Chalk to be removable far easier then it is right now. Currently it's hard-mounted. I want to work it so the all that I have to do is remove some pins and then the unit can come out. Much like my loading ramp. I have the front hatch rigged with Flag Hinges to make removable as simple as opening the door and lifting it off.
    I'm also thinking about adding forward storage bins that will be accessible from a securable top hatch. That would mean storing the ramp under the trailer. Not a big deal, just a bit more time consuming. I'll look at tackling that project after I get back.
    There are a couple of other "Upgrades" I want to look at too. Including stronger tires (current tires are 2 ply sidewall and rated to a max load or 500lbs), beefier axle, hubs and leaf springs. The whole trailer as it currently sits, can handle a load of up to 500lbs (perhaps a bit more for shorter runs) and I'd like to get it to 1,000lbs capacity. That way I can rig it to carry 2 bikes safely!!
  5. #185
    apriliaforum expert Rosscofat's Avatar
    Vancouver BC
    I better get working on mine again. Lol just spent 3600$ on a new trans for the Kia ( put a hole though the last one) haha
    Love how the straps are done. must not move a inch.
  6. #186
    apriliaforum expert DetonatorTuning's Avatar
    May 2011
    Indiana
    Quote Originally Posted by Louder North View Post
    i'll put money on you'll wish you had remounted the front wheel chock up onto a piece of 2x before you get there.
    no ill wished, Murphy stay home, but it could still pass impact and movement the way it is.
    steve
    2003 SR70
    HGT PFI system w/ Bing 26mm dual injector TB, HGT PFI Regulator, HGT ECU, Malossi ECU for gauges
    Malossi 360 intake manifold, Malossi MHR crank and bearings
    Engine block match ported to Airsal T6 70cc cylinder and Malossi VL 14 reed block
    Exhaust port optimized for Malossi MHR Team II pipe.
    Malossi Multivar 2000 w/ 4.25g Dr Pulley sliders, Malossi Belt
    Malossi Delta clutch, Yellow Malossi springs, MHR weights, White Contrast Spring, Malossi TC, Malossi 15 / 40 gears
    HGT Morini stretch kit and shock riser, Scarabeo 50 16" rear wheel and tire.
    MASSIVE PIXY DUST !!
    Rider; 5-4, 130#'s
  7. #187
    Sep 2008
    Hummm.... Well, the front of the wheel chalk is mounted directly to the front framing beam. The roads I took her over (some of the worst Winnipeg has and the newest) and she was rock solid.
    Plus, adding anything under the chalk would raise the over all height necessitating a total change in how it's mounted. It would have to be moved back at last 3" to 4" leaving me with no room out back for the gate. Unless you were refering to the underside...
    And just to be sure/safe, I'll be making regular stops and have a bit of a checklist of things to look for/check to insure a safe trip...
  8. #188
    Vancouver BC
    Quote Originally Posted by Grenadiers View Post
    how many Tie downs do you have in total? 6? front wheel, rear wheel, left handle bar, right handlebar, and 2 around the middle?
  9. #189
    Sep 2008
    Quote Originally Posted by Rosscofat View Post
    At this point I've got 4, and with that, I used one tie-down strap for each side of the handle bar, one for the rear tire and one on the diagonal (right front anchor to left rear anchor) that went across the seat. I have 2 more tieown straps and may use them. I also have 2 more tie-down anchors that I could install at the mid point between the 4 I have currently installed. however, based on my trial run, I don't thnk I'll need it. The rear tie-down actually pulls the bike back as it it jut situated behind the rear tire.
  10. #190
    Vancouver BC
    ahh ok that makes more sense. I thought I saw 2 going over the tunnel.. after looking again you just lay them over it.
  11. #191
    Sep 2008
    Correct... I picked up tie-down ratchets that were 20' in length... as a result, i have REALLY long tails, so I used them across the tunnel and tied them into the anchors just to add a bit...
  12. #192
    Vancouver BC
    ahhh perfect. I got the handle bar straps just trying to find the best ratchets
  13. #193
    Sep 2008
    I'm using 15' X 1" ratcheting straps... think you will run into problems if you go with wider one. The one of the sets I got came from Princess Auto when it was on sale. HERE is the first set I picked up... I also picked up THIS set of 6' X 1" set of 2 yesterday, I got it on sale for $9.99 (regular $19.99) but in camo colour...
  14. #194
    Vancouver BC
    Oo I like.. I am just getting the floor for the trailer cut to size right now. then some C Channel tubing will hold it in place once on the flat deck.
  15. #195
    Sep 2008
    Yeah, they held on very tight... I may do one more test ride in a couple of weeks... See how I feel...
