View Poll Results: Are you interested in a Ditech Water Trap Kit if available?
Voters
32. You may not vote on this poll
  • Yes, show me your kits!
    29 90.63%
  • No, I would rather buy all the parts myself separately.
    3 9.38%
Results 16 to 30 of 48
Thread: Testing the Water - Complete Water Trap Kits
    Vancouver BC
    I would not mind just a higher quality Trap it self. What do you have Snugg? you can PM me if you like
    May 2011
    Finland
    Would it be possible to ship to Finland?
    2010 SR50 R Factory - Piaggio Purejet
    ECU Derestricted (2.8.0) / LeoVince ZX-R / Water Trap / NGK ZMR7AP (.035") / +3° Woodruff Key
    Malossi Multivar 2000 / 7.5g Sliders / Malossi White Contra Spring / Polini Blue Clutch Springs
    Stage6 Wing Cooler Clutch Bell / Malossi Red Sponge Filter
    Michelin Pilot Sport SC 130/60-13 (front and rear) / Buzzetti Sidestand / Polished Variator Cover
    Lennes SR50 Aluminium Foot Plates & Radiator Grille / Kiesler Underseat / Stage6 Mirror
    Jan 2012
    H-Town, Tx
    Hey Snugg. I would buy one, I been looking to get the parts but if you have it assemble and stuff I would def buy one lmk
    apriliaforum Member tiojeffe's Avatar
    Darwin NT
    I will buy one too, I can't get my head around it when I look at all the different options. Are you ready to go international man?
    2002 Morini Ditech SR50
    Malossi big block kit
    Malossi full circle crank
    HGT fuel pressure reg S II stealth black
    Koso dash
    Malossi Variator Kit Multivar 2000
    7g rollers, White Contra Spring
    Malossi Torsion Control
    PMR8A indexed, gaped to .35
    Max's TB Mod
    Leo Vince ZX-R
    EAI Starter Circuit breaker Mod
    Buzzetti side stand
    Woodruff key
    VL12 Carbon Reed Valve
    Marchald Air filter
    15/40 = 1:2.67 Gear box primary drive
    EAI LED low and high beam conversion
    EAI LED Daytime driving lights
    moisture trap
    Jan 2012
    H-Town, Tx
    so what about them water traps snugg?
    apriliaforum prov-nov JCrabb1138's Avatar
    May 2011
    Port Angeles, WA
    where do I fill out the order form?
    2009 SR50 Piaggio
    Removed restrictor plate & variator washer
    ECU Derestricted (Unknown Mapping)
    Banned Snugg's Avatar
    Aug 2007
    Aurora, CO
    There wasn't that much of an interest for me to invest in all the parts. If you're interested. PM me with what options you would like and we can just do them individually
    apriliaforum expert toddlamp's Avatar
    Nov 2007
    Laurel, MD
    If you're not going to do it maybe I will ;-)
    All I need to do is find a quality filter. I will probably end up using the one from Harbor Freight but I know there has to be something out there of better quality. I definitely am not going to use the one from Home Depot. I tried at least 2 of them and the manual valves both leaked when closed.
    2010 SR 50 R Factory (max speed so far downhill/tucked: 70mph indicated)
    1. De-restricted (2.8.0)
    2. Leo Vince ZXR pipe
    3. NGK ZMR7AP (gap: 0.035")
    4. Malossi Multivar 2000 w/7.2g Rollers
    5. White contrast spring
    6. Red clutch springs
    7. Malossi TC
    8. Malossi VL13
    9. Harbor Freight Water Trap
    10. Stage 6 gear kit 13/39
    11. HGT Fuel Regulator @ ~118psi
    apriliaforum Junkie Aprilia sr50 02's Avatar
    Dec 2011
    Brisbane,Australia
    Snugg so did you end up getting some water traps together ? I've done alot of reading and finally decided to get myself one .
    Is there any prices ? I would be definitely interested in a STEALTH one.
    Aprilia SR 50 02 Ditech Morini Engine
    Malossi Variator kit (7.5 Gram rollers)
    Leo Vince Exhaust ZX-R
    Derestriction with 2.80 software
    HGT REGULATOR
    YSS Racing Suspension
    Castrol TTS Racing 1 Oil, NGK-CPR8-E Spark Plug (tried ZMR7AP and doesn't perform as good for me)
    Aug 2007
    Aurora, CO
    I only did a limited amount of kits. 20 of them and they all sold already. The price for STEALTH kits was $69. Sorry, there wasn't enough interest to start anything larger up. And since I sold all of my scooters, I won't be making any more.
    Nov 2007
    Laurel, MD
    PMed you Snugg.
    7. Malossi TC
    8. Malossi VL13
    apriliaforum expert Culverin's Avatar
    Nov 2009
    Vancouver, BC, Canada
    Any chance you can share what parts you ended up using?
    SR50 R Factory / 2009 / Piaggio Purejet
    General
    Restrictions: Removed / Tires:
    Michelin Pilot Sport SC 130/60-13 (front and rear) w/ 2.0g dynabeads / Rider Weight: 56.7kg (125lbs)
    Performance
    ECU: unknown Version and Mapping
    Spark: NGK ZMR7AP (gapped to approx. 0.037mm)
    Exhaust: LeoVince GP, silencer removed
    Variator: Malossi Multivar 2008 w/ 6.0g DP sliders
    Contra Spring: Malossi Purple w/ Malossi Torsion Control + Stock Piaggio TC (clutch side).
    Clutch: Malossi Delta / Yellow Clutch Springs (7250 rpm engagement according to this table) / Wing Clutch Bell
    Reed Cage: Malossi VL13 (stuffer removed)
    Status
    - Clutch might still be engaging too soon? Too late? Not really sure?
    - Off-the-line lag is gone. woot.
    Parker Colorado
    Quote Originally Posted by Snugg View Post
    Anyone here purchase one?
    Any pics?
    Nov 2007
    Laurel, MD
    I'd like to know too. I'd be interested in selling a kit and feedback from those that purchased from Snugg would be great!
    7. Malossi TC
    8. Malossi VL13
    Dec 2011
    Brisbane,Australia
    Well if anyone decides to make up another kit soon, pm me as I am keen to get one in the next couple of weeks, thanks.
    HGT REGULATOR
