Hi team
I wrote off my flashy giallo Falco a few months back and am now clearing out the odds and ends I have in the garage:
Lot 1
Flashy Giallo rear seat cowl - immaculate
Lot 2
Left handlebar
Lot 3
USA spec Falco sidestand - the one with 3 mounting holes - 1 needs to be ground off for use on non USA bikes.
Lot 4
Left Aprilia Racing SL Carbon pipe. It has a very light 6mm scratch and a small heat mark on the inside front of the pipe from exhaust gasses (see photo). End cap perfect, feeder pipe should polish up OK
Aprilia Racing SL Carbon EPROM plus EPROM puller
Lot 5
Standard exhaust pipes - used once for rego. Yeah I know, hardly unique but they might help someone and I don't care how much these go for. Otherwise they go to Sims metal.
Lot 6
Custom made socket spanner to adjust the rear fork pin nut (rear swingarm). It does the job of part number 8140203 for the rear fork pin (it does not do engine mounts).
New:
Two EMGO oil filters. Two OEM oil filter o-ring seals
Two needle bearings for rear shock linkages, etc. Part number 8110065
Two needle bearing covers for rear shock linkages. Part number 8110068
Rear brake / gear lever rubber. Part number 8120912
Lot 7
Set of Brembo front rotors, swapped out as they had a slight vibration.
My spare set (bought them from Exdukenut) were ground by Planet Discs (03) 9801 7067 in Wantirna South, VIC and I had them on the bike. I never got around to sending the original set to Planet Discs.
Lot 8
Evoluzione race oversize air box kit with high flow filter, part number 75014
Also a tube of K&N air filter sealing grease, about 70% full
Make me an offer for a Lot or "the lot" - I am keen to sell it all rather that throw it out.
Cheers
Stephen
Sydney
"I like to put a little silicone grease on the seals, too, to keep them looking young and fresh like a prom queen." - SoulDaddy
Trying to think of a reason I would need a spare cowl though. If no one else wants it let me know what it would take to save it from the bin.
