Results 1 to 14 of 14
Thread: rs 50 tnt 21mm carb running too rich
    apriliaforum newb bradley,rs 50's Avatar
    Dec 2011
    leeds
    hi, im having problems with the carb running too rich, i have a 21mm tnt race carb with a 95 main jet and im getting alot of black oil coming out of the exhaust manifold all down my trousers,any help please on adjusting the carb ?
    aprilia rs 50:
    polini 80cc bore
    polini race reeds
    doppler wr7 race exhaust
    21mm race carb
    race resin crankshaft
    malossi air filter
    Nov 2011
    cumbria england
    if youre getting black smoke out the pipe then its far too rich smaller main jet will be the answer but im sorry havnt got a clue what size
    Nov 2005
    Netherlands
    Dont think its to rich if you got a Malossi filter on there... but in an other thread i already recomended to take that off and fit the stock airbox back on, its better, and easier to set up than, and you probably even get more power out of your setup, and all this especialy aplies in winter.
    It might be you popped a oil seal, or the cilinderhead gasket is leaking cooling fluid.
    Nov 2011
    cumbria england
    black smoke usally means too much fuel
    white smoke is oil or white steam could be water
    but as patrick says good place to start is the air filter
    if its blooked or not letting the right amount off air through then it will ritchen the fuel/air mixture
    its a very comon mistake to make that a aftermarket air filter will improve performance but it very rarly does and they are always wanting attention if you do get them set up right they get more dirt than a standard fillter and also hold water as they are sucking everything in unlike the standard filtters that have a little protection from the weather due to being in a enclosed air box
    May 2010
    Plymouth
    Im putting my money on a bad oil seal however i still agree it could be to rich
    Dec 2011
    leeds
    All oil seals we're replaced and are fine, and I don't have the standard air box , can you not turn the amount of oil you let in from the carb, also it only smokes on a morning and it is white smokee
    aprilia rs 50:
    polini 80cc bore
    polini race reeds
    21mm race carb
    malossi air filter
    Nov 2011
    cumbria england
    if its white smoke its oil which is normal to a point
    black smoke is too much fuel not enough air nothing to do with the oil pump
    and its comon to have a little more white smoke when sarted from cold than after its warmed up
    Dec 2011
    leeds
    But a lot of oil is coming out of the exhaust that isn't gettin burnt and is just being spat out the exhaust
    aprilia rs 50:
    polini 80cc bore
    polini race reeds
    21mm race carb
    malossi air filter
    Mar 2011
    Los Angeles
    It's 2 stroke, get used to it. My rs doesnt have fairings so I get plenty of splatter and have to wipe it down after every ride.
    Nov 2011
    cumbria england
    sorry missread original post thought it was black smoke not black oil it is common to have a a little oil around the tail pipe on a 2 stroke
    it depends what you class as a lot of oil
    you could try disconecting the oil pump and running on pre mix add 100ml of 2 stroke oil to 5 ltrs of petrol in a can give it a good shake about to mix it but better putting oil in first then add the fuel to help mix it then poor it into drained fuel tank
    if you try this take the cable off the pump disconect the oil pipe and block both ends to stop air being drawn in to the carb/manifold and also to stop any oil being pumped out
    but if it was burning too much oil this would be white smoke
    Jun 2012
    gillingham
    Quote Originally Posted by bradley,rs 50 View Post
    what is the size of the main jet on that carb as i may get a tnt 21mm. is it a 5mm, 4mm or 6mm main jet ? and what make is yours?
    apriliaforum expert Glen1990's Avatar
    Nov 2011
    Barrow in furness
    hmm jet sounds about right to me
    Aprilia rs 50 2000
    Top performance Pink 75cc
    Doppler Endurance crankshaft
    Arrow racing exhaust with carbon endcan
    Dellorto 21mm carb(92 main jet)
    Stock air box modded
    Top performance Cdi
    Malossi reed block 0.30mm
    Conti race clutch kit
    14/47 Gearing
    Mono rear
    Michelin pilot sport tyres
    Rs 125 front master cyilinder
    Malossi upgraded clutch springs
    Rs 125 Headlight
    UPGRADES to come
    24mm mikuni flatside carb
    Double bubble screen
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    Full respray and frame polish
    Doppler air rear shock
    Nov 2005
    Netherlands
    White Smoke = Cooling Fluid
    Blue Smoke = 2 Stroke Oil
    Black Smoke = Gearbox Oil
    If the engine is cold and you start it the white smoke is condensation from the moisture over night, wen the engine is warm it should disapear.
    If you dont do long enough rides for the engine and especaily tghe exhaust to heat up fully than condensation vaports and unburned residue togethert with sooth mix into a black oily gunk wich drips from the exhaust.
    Wen my engine is fully warm and i put a white cloth behind the exhaust and rev it the cloth stays white, no spray what so ever, the only thing you might see its that it turns a little carramel brown from the exhaust gass and heat.
    Nov 2005
    Netherlands
    Quote Originally Posted by scaramanga View Post
    You need to take the pump off, or remove the gear that drives it or the oilpump seizes up.
    These bikes run 1:35 mix, not 1:50, and with his setup the oilpump is never gonna put out to much oil, infact he needs to add an adtional 1:100 to 1:50 (1:50 because he doesnt have a stock airbox) trough the feul with the oilpump working.
