basically have a question about the front fairing being the same from any of the earlier mille models, thank you
The title of this thread and your question above ask two very different questions.
The answer to the title is yes 2001-03 are the same.
The answer to the question posed above for ANY of the earlier model Milles is no they are not all the same. 98-00.5 Millies have different upper front fairing, windscreen and headlight modules than the 01-03 bikes. That being said the whole front fairing as unit can be swapped between 98-00.5 and 01-03 bikes but the individual components can not be mixed and matched.
It didn't make sense to me, either...
BTW, a good place to get some basic info can be found in the sticky thread: Beginners Guide to Aprilia Rotax Ownership:
:http://www.apriliaforum.com/forums/s...d.php?t=201706
Also - Under the 'Shop Online' tab on the top tool bar you can find parts diagrams for every model and every year - you can see right there what fairings fit various years.
And yet another thread discussion the various differences between model years that is stickied in the 1000cc FAQ sub forum that would help.
Finally, the 'Search' function works and is always a wise place to look for info that is readily available.
WAFO
