Results 1 to 3 of 3
Thread: FP regulator install question
    Nov 2003
    California Bay Area
    Question FP regulator install question
    So, since my local Aprilia shop is too damn busy....
    Anyone installed the Evo FP regulator? Is it very tough to do? Any special tools needed?
    TIA
    Sydney, Australia
    Takes about 40-60 mins to do. You are better off doing this with as little fuel in the tank as possible, because some fuel will spill out the 2 lines into the bodies (one each side). Try to not cut (with the hacksaw) too low on the regulator. You want to cut just below the little pipe (vacuum line pipe), on the regualtor.
    But it isn't too hard.
    As you are in the US and all the bolts etc are in AF measurements, then you will find it a lot easier, rather than us people who have metric tools. All the requirements are on the instruction sheet.
    Nov 2003
    California Bay Area
    Thanks!!
  1. Re-using hose clips / Tank/pump question
    By Kiwi_M5 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 10-09-2011, 08:05 AM
  2. Slip-on install question
    By RedFive in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 09-16-2005, 11:18 PM
  3. PC III question for Clarkie ...
    By Pierre in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 09-12-2005, 04:39 PM
  4. New Futura Owner - Pannier Compatibility Question
    By HarryFutura in forum RST1000 Futura (all years)
    Last Post: 03-15-2005, 01:44 PM
  5. Another Newbie Question
    By skrump in forum General Motorcycle Talk
    Last Post: 07-15-2004, 01:32 AM
