Page 1 of 9 123 ... LastLast
Results 1 to 15 of 126
Thread: Oil Jet - Difficulty Finding Neutral
    Mar 2007
    Palos Verdes Est. SoCal
    out for a stator test ride;
    with a new clutch oil jet Aprilia part #0268751 size 40 and a new seal in the slave [i found replacement seals at the rebuilder [because brembo does not sell kits]
    the seal is marked "25 DJF 3505817 1 1/8 H" it is a standard 1 1/8 th inch master cylinder seal
    seal dimentions;od 29.5mm, id 18.5 [tapered] and 4.4mm wide]
    AF1 has slave seals too
    '04 &'05 come with a #60 jet, '06 and later with the #40
    there have been later bikes reported with the larger #60 jet so you might want to check
    the jet was $8 the seal $3 best money spent on the bike yet
    no creep, no drag and neutral without thinking, wish i'd done this 30,000 miles ago
    Noel-theknurl
    apriliaforum expert aprsv2007fl's Avatar
    Jul 2007
    Clearwater, FL
    congrats on the easy fix
    Tampa Managed Services | Tampa Computer Support | Tampa IT company | Tampa SEO
    "Some have said the Bush administration has not adequately pressed Musharraf in the search for Bin Laden, but intelligence experts counter that it can be quite difficult to spot a 6' 5" elderly millionaire undergoing regular dialysis in a rural area."
    07 RSV-R
    Mods
    Leo Vince, Gen III Highmounts
    Axone Map-2
    520 Gold Chain 16/44
    Pazzo Racing Levers
    Carbon Hugger
    Mar 2007
    fix
    Quote Originally Posted by aprsv2007fl View Post
    well it did take a while to hone the hard annodize out of the slave cylinder to smooth it, [the rough surface/return spring is where i think the air comes in as the vacuum drops] but now i have a real clutch. i recommend this mod to everyone
    i only bled my clutch once in 29,000 miles, but the change is like night and day.... little wiggle of the toe and you're in neutral.
    Noel-theknurl
    apriliaforum expert RSV Boy's Avatar
    Aug 2006
    Wellington, New Zealand
    "Oil jet"
    Hi Noel, where is this jet? sounds like a great fix.
    apriliaforum Junkie tdogg's Avatar
    Aug 2006
    Flagstaff, AZ
    It located right above the clutch slave. The jet is rather difficult to get out with out some very small tweezers or something but it is really easy to to get to. Just pull lthe cover bolt out and the jet is behind it.
    Aug 2006
    Thumbs up
    Thanks tdogg, I have been thinking about a new slave, mines not really ever had a problem, but it is quite heavy, and I'm changing gear alot in the tight twisty roads over the mountains. Maybe MPL or Evo' ??
    Wellington NZ
    Quote Originally Posted by RSV Boy View Post
    Changing gear using the clutch??? I'd be interested to find out how that works out for you, as mines quite heavy.
    apriliaforum expert StefanJ's Avatar
    Feb 2005
    Back from the Ghan, in Alaska!
    I'll be trying this. I just want to make sure I pull the correct bolt off.
    Any pictures from the side?
    WERA Novice #425(before I deployed, now I'm a bench warmer)
    God and the Soldier, we adore,
    In time of danger, not before.
    The danger passed and all things righted,
    God is forgotten and the Soldier slighted.
    ~Rudyard Kipling
    Only two defining forces have ever offered to die for you:
    1. Jesus Christ.
    2. The American G.I.
    One died for your soul, the other for your Freedom
    apriliaforum prov-nov twowheelblonde's Avatar
    Jul 2007
    Phoenix, AZ
    Noel - so just to clarify, are you recommending this as a fix for the annoying air leak problem? (lucky you don't have it) or is it just a friendlier performing clutch that eliminates those other annoying issues.
    Betty
    '07 RSVR Factory
    '06 Yamaha Midnight Warrior
    May 2008
    San Diego, California
    Attachment 84019
    Here's a shot from the side. I hope you can see the red arrow.
    Remove that bolt and the jet is underneath. You don't have to drain the oil, but a few tablespoons will drain out anyways. Use as big a screwdriver as you can get into the slot of the jet since you don't want to damage the soft brass when un-threading it. Grab the old one with tweezers or something and take it out.
    Install the new one and only make it as tight as needed to keep it from un-screwing itself. It's not like the jet is holding anything together, so almost no torque is required. Install the bolt again and torque it to 100 in-lbs. Go ride and make sure it doesn't leak!
    Please keep in mind that a badly-bled clutch master and/or slave cylinder will cause the same problems, so check that first since it doesn't cost anything.
    apriliaforum expert burnham's Avatar
    Jul 2005
    Massachusetts
    The oil jet won't do anything for the air leak.
    Feb 2005
    Awsome!!!!
    Thanks so much!!!!
    ~Rudyard Kipling
    1. Jesus Christ.
    apriliaforum expert fast4d's Avatar
    Jun 2006
    LA, CA
    I did the oil jet couple weeks ago. that and a good bleeding fixed my neutral problem. I used a really thin drill bit to get the old jet out.
    Alan
    '04 RSVR Factory (parted)
    '08 KTM SuperDuke R (sold)
    2000 Kawasaki ZRX1100
    2011 KTM RC8R
    2012 BMW S1000RR
    Feb 2005
    Quote Originally Posted by fast4d View Post
    Drive through Ojai much?
    I can't wait to try it out! I just need to take some time to do it. Most of my time is being spent with family when I am not on mission which seems to be quite frequent these days.
    ~Rudyard Kipling
    1. Jesus Christ.
    Jun 2006
    LA, CA
    Quote Originally Posted by StefanJ View Post
    yes but I usually ride my motard up the 33.
    if it's late the 150 gets jammed with cars then it might be better to take the 101 and up 33.
    it might be a bit wet (and possibly snowy) and dirty this weekend.
    Alan
    2011 KTM RC8R
    2012 BMW S1000RR
