Results 16 to 30 of 39
Thread: Wheel comparison, weight & dimensions
    I just weighed a rear Brembo off an 01 on a triple beam balance with bearings and seal and drive flange with bushings. No axle spacer, disc/bolts, or valve stem. Comes in within a gram or two of 7 kilos. 15.43 lbs
    apriliaforum expert Gtrain's Avatar
    Apr 2006
    Melbourne
    Looking at all the weights of these wheels, some of them just don't add up.
    The weights of the cast Brembos in particular.
    AF1 list the Stock cast front as 11.85lbs which converts to 5.4kg.
    Yet some have weight these ranging from 4.2kg (9.2lbs) to 4.4kg (9.7lbs)
    (cast fake oz front wheel 4.9kgs save 500grams/ 1 pound off AF1 weights)
    AF1 Stock cast rear wheel: 17.95lbs (8.2kg)
    weight by others 6.7kg (14.7lbs) to 7kg (15.4lbs)
    (cast fake oz back wheel 7.5kgs save 700grams/ 1.1/2 pounds off AF1 weights)
    What I'm trying to say is maybe if AF1's weights are correct then the cast oz copies would be a half way weight saving on the way to forged wheel weights.
    Cheap bastids like me could get oz looking wheels and save a little bit of weight, just not as much as the expensive real deals
    EDIT: Just to confuse some more Aprilia state that the RSV4 forged wheels are, front 1.7kg lighter than stock and rear 2.4kg lighter than stock.
    This would mean when you put the two together (weight saving from aprilia added to Amauri weight of the RSV4 wheels, you get a stock wheel weight (cast) of, 4.67kg front and 7.15kg rear, about 1.78 kgs lighter than cast brembo wheels if AF1 weights of them are correct.
    Quote Originally Posted by Gtrain View Post
    That's why I started this thread, using the same scale for all measurements.
    New Braunfels, TX
    the cast OZ look alikes found on 06-09 base Tuonos and base RSVRs are heavier than the older 5-spoke cast wheels from Brembo
    Ed Cook AF1 ed@af1racing.com
    AF1 Racing Online Store
    Dec 2004
    uh, L.A.
    Ed, by how much? Got a scale lying around?
    Cogito Ergo Vroom
    Dec 2004
    uh, L.A.
    Ok, I don't have the most precise scale, but . . .
    I just weighed a set of the stock Aprilia OZ-copies from a 2009 DD and the weights are very close to what AF1 has listed.
    Rear is a touch under 18 pounds.
    Front is a little under 12 pounds.
    Keep in mind that these wheels have EVERYTHING on them: spacers, cush drive, cush rubbers, bolts, hardware, valves, etc -- even a couple ounces of balancing weight. So actual clean/stripped wheel weights will be lower.
    Sorry I can't be even more precise but my more delicate scale tops out at 10 pounds so I can't use it for these.
    Hope this helps.
    (And by the way, these wheels are FOR SALE right now here:
    http://www.apriliaforum.com/forums/s...96#post2632996 )
    Cogito Ergo Vroom
    Marchesini rear forged aluminum 11 lb, 15.7oz or 5.4 kg
Name:	march alum r.jpg
    Marchesini front forged aluminum 8 lb, 11.1oz or 3.9 kg
Name:	march alum f.jpg
    Marvic Penta cast mag rear 9 lbs 3.1oz or 4.15 kg
Name:	marvic penta r.jpg
    Marvic Penta cast mag front 6 lbs 8.7oz or 2.96 kg
Name:	marvic penta f.jpg
    apriliaforum prov-nov Sileighty_guru's Avatar
    Sep 2011
    Maine
    Those are sexy! I like the color
    apriliaforum expert RZRob's Avatar
    Anaheim Hills California USA
    Quote Originally Posted by Sileighty_guru View Post
    You took the words right out of my mouth.
    RZ Rob
    Keep the Rubber Side Down
    Bikes
    2004 Aprilia RSVR Factory - Silver (the fastest color)
    2007 Aprilia SXV 550 - Plated
    1999 Aprilia RS250 - Plated
    2003 Honda CRF150 - Plated (girlfriend's toy)
    2006 Honda CRF450 - Fun Toy
    1970 Honda Z50 - Plated (pretty clean)
    GoPed Sport - Conquered IOM TT in 2000
    I was surprized at how much heavier those Marchesinis are compared to the std blue OZs
    Aug 2011
    Italia
    On the same base, no tyre, no brakes, what's the weight of the rsv4r aprc / tuono v4 ? Tnx a lot
    As soon as I get one in for a tire change, I'll weigh and post those numbers.
