Results 1 to 15 of 26
Thread: Wheel comparison, weight & dimensions
    I originally started this thread to compare the weight of the many wheels available to fit the RSV, Tuono & Falco. I’ve updated it each time I found another set of wheels to weigh.
    As you can see from the photos, I’ve been using the same scale for all measurements. This way we can make an accurate comparison.
    Aprilia now has added the Shiver, Dorsoduro, Mana and RSV4 models to the lineup.
    Fortunately, they kept the exact same wheel dimensions as before, so the older wheels will fit the newer bikes as well.
    Rotor bolt pattern and dish is the same for all years.
    Even the 25mm axles, axle nuts and wheel spacers are all the same, front and rear.
    Note, the RSV4 and V4 Tuono uses a 10mm longer rear axle.
    There is a small difference in wheel mounting dimensions that Aprilia changed starting with the 2003, 04 RSV.
    Front:
    All bikes equipped with radial mount front brake calipers have a 5mm wider rotor mounting flange (see photo).
    Radial caliper front wheel = 115mm
    Axial caliper front wheel = 110 mm
    AF1 sells machined spacers to adapt the early wheels to later bikes:
    http://www.af1racing.com/store/Scrip...idproduct=2421
    Rear:
    Starting with the 2004 RSV, 06 Tuono, Shiver, Dorso, Mana and RSV4, the rear wheel sprocket hub has been moved 3mm to the left of the rim centerline. The rear brake rotor to rim center distance is the same on all years.
    2011 APRC RSV4 introduced a small change on the rear brake rotor mounting to accommodate the sensor ring.
    http://www.apriliaforum.com/forums/s...0&postcount=17
    Many of us use the older wheel on the newer bikes without issues, though the chain line will be slightly off, it is such a small amount that it has no effect on chain/sprocket wear.
    Some people have used a shim to space the cush hub out the extra 3mm.
    Nera front 7 lb, 0.7oz or 3.2 kg
    Marchesini forged Mag rear wheel 9 lb, 3.1oz or 4.17 kg
    16.5" Marchesini forged Mag front 5 lb, 11.2oz or 2.6 kg
    Tuono Racing rear wheel 11 lb, 13.7oz or 5.37 kg
    Tuono Racing front 7 lb, 14.9oz or 3.6 kg
    Weighed a set of BSTs today.
    Like the others before, I used the same scale, no rotors or tires. Bearings and spacers included.
    front 5 lb, 6.1oz or 2.5 kg
    BST rear 8 lb, 7oz or 3.8 kg
    Blue front from 05-Factory 7 lb, 9.5oz or 3.5 kg
    Blue rear from 05-Factory 11 lb, 2.7oz or 5.1 kg
    old style rear OZ from 2001 RSVR 12 lbs, 1.4oz or 5.5kg
    Marvic Piuma magnesium 16.5" rear 9 lbs, 14.6oz or 4.50kg
    Marvic Piuma magnesium 16.5" front 6 lbs, 11.2oz or 3.0kg
    RSV4 Fact front 6 lbs 8.5oz or 2.97kg
    RSV4 Fact rear 10 lbs 6.6oz or 4.75kg
    Marchesini rear forged aluminum 11 lb, 15.7oz or 5.4 kg
    Marchesini front forged aluminum 8 lb, 11.1oz or 3.9 kg
    Marvic Penta cast mag rear 9 lbs 3.1oz or 4.15 kg
    Marvic Penta cast mag front 6 lbs 8.7oz or 2.96 kg
Name:	march alum r.jpg
Name:	march alum f.jpg
Name:	marvic penta r.jpg
Name:	marvic penta f.jpg
    I just weighed a rear Brembo off an 01 on a triple beam balance with bearings and seal and drive flange with bushings. No axle spacer, disc/bolts, or valve stem. Comes in within a gram or two of 7 kilos. 15.43 lbs
    apriliaforum expert Gtrain's Avatar
    Apr 2006
    Melbourne
    Looking at all the weights of these wheels, some of them just don't add up.
    The weights of the cast Brembos in particular.
    AF1 list the Stock cast front as 11.85lbs which converts to 5.4kg.
    Yet some have weight these ranging from 4.2kg (9.2lbs) to 4.4kg (9.7lbs)
    (cast fake oz front wheel 4.9kgs save 500grams/ 1 pound off AF1 weights)
    AF1 Stock cast rear wheel: 17.95lbs (8.2kg)
    weight by others 6.7kg (14.7lbs) to 7kg (15.4lbs)
    (cast fake oz back wheel 7.5kgs save 700grams/ 1.1/2 pounds off AF1 weights)
    What I'm trying to say is maybe if AF1's weights are correct then the cast oz copies would be a half way weight saving on the way to forged wheel weights.
    Cheap bastids like me could get oz looking wheels and save a little bit of weight, just not as much as the expensive real deals
    EDIT: Just to confuse some more Aprilia state that the RSV4 forged wheels are, front 1.7kg lighter than stock and rear 2.4kg lighter than stock.
    This would mean when you put the two together (weight saving from aprilia added to Amauri weight of the RSV4 wheels, you get a stock wheel weight (cast) of, 4.67kg front and 7.15kg rear, about 1.78 kgs lighter than cast brembo wheels if AF1 weights of them are correct.
    Quote Originally Posted by Gtrain View Post
    That's why I started this thread, using the same scale for all measurements.
    New Braunfels, TX
    the cast OZ look alikes found on 06-09 base Tuonos and base RSVRs are heavier than the older 5-spoke cast wheels from Brembo
    Ed Cook AF1 ed@af1racing.com
    AF1 Racing Online Store
    Dec 2004
    uh, L.A.
    Ed, by how much? Got a scale lying around?
    Cogito Ergo Vroom
    Dec 2004
    uh, L.A.
    Ok, I don't have the most precise scale, but . . .
    I just weighed a set of the stock Aprilia OZ-copies from a 2009 DD and the weights are very close to what AF1 has listed.
    Rear is a touch under 18 pounds.
    Front is a little under 12 pounds.
    Keep in mind that these wheels have EVERYTHING on them: spacers, cush drive, cush rubbers, bolts, hardware, valves, etc -- even a couple ounces of balancing weight. So actual clean/stripped wheel weights will be lower.
    Sorry I can't be even more precise but my more delicate scale tops out at 10 pounds so I can't use it for these.
    Hope this helps.
    (And by the way, these wheels are FOR SALE right now here:
    http://www.apriliaforum.com/forums/s...96#post2632996 )
    Cogito Ergo Vroom
    apriliaforum prov-nov Sileighty_guru's Avatar
    Sep 2011
    Maine
    Those are sexy! I like the color
    apriliaforum expert RZRob's Avatar
    Anaheim Hills California USA
    Quote Originally Posted by Sileighty_guru View Post
    You took the words right out of my mouth.
    RZ Rob
    Keep the Rubber Side Down
    Bikes
    2004 Aprilia RSVR Factory - Silver (the fastest color)
    2007 Aprilia SXV 550 - Plated
    1999 Aprilia RS250 - Plated
    2003 Honda CRF150 - Plated (girlfriend's toy)
    2006 Honda CRF450 - Fun Toy
    1970 Honda Z50 - Plated (pretty clean)
    GoPed Sport - Conquered IOM TT in 2000
    I was surprized at how much heavier those Marchesinis are compared to the std blue OZs
    Aug 2011
    Italia
    On the same base, no tyre, no brakes, what's the weight of the rsv4r aprc / tuono v4 ? Tnx a lot
    As soon as I get one in for a tire change, I'll weigh and post those numbers.
    Jun 2009
    Wow, those Marvics give the BSTS a run for their money as far as weight....no-where near as sexy though...
    Sorry you think it's intolerant of me to not tolerate your intolerance.
    2007 RSVR 1000- Yeah, It has a few upgrades.....
    We used to earn the things we desired in life. Now we're just encouraged to put our hand in the next guy's pocket.
    - Don't go where trouble is likely to find you.
    - Some people attract trouble. Don't associate with them.
    - If you're minding your own business and trouble finds you anyway, do what it takes to de-escalate and walk away.
    - If walking away isn't a viable option, consider running.
    - If you have considered and/or exhausted all of your other options and you must fight to defend yourself, fight to kill.
    apriliaforum expert kevinb's Avatar
    Feb 2010
    New York
    Quote Originally Posted by scubacat View Post
    And they look crazy fragile, too.
    I'd really like to get some lightweight wheels, but BST and Marvics seem to really push the envelope. I'd be afraid I'd break them on some of the rough streets around Manhattan and Brooklyn I have to ride. Any engineers or materials scientists out there with suggestions?
    Oh, and those gray Marchesinis ARE hot.
    Kevin
    2008 RSV R - "Lara" Third time's a charm?
    2006 MTS 620 - "Crazy Cat" - RIP
    2006 MTS 620 - "Rosebud" - RIP
    Many have forgotten that Marvic is one of the oldest foundry specializing in magnesium castings.
    In fact, Mr. Marchesini started out as an employee of Marvic.
    http://www.yoyodyneti.com/Product/ma...esentation.mov
    They make a very good wheel, both cast and forged types.
    Also keep in mind that a true race wheel is intended for lightweight race bikes.
    They may not be strong enough for a street bike that weighs 100+ lbs more, especially when you also consider that many of us weigh quite a bit more than most pro racers. Do you carry a passenger?
