To display fault codes:1) Remove right side panel (the piece that covers the rear subframe and lower gas tank) by removing the two 4mm button-head Allen bolts. Be careful of the plastic tabs on the backside of the panels.2) You will find two unconnected wires near a big harness clip near the side of the battery. You cannot miss these wires. They are the only 2 unconnected wires in there.3) Connect the two wires together.4) Turn key switch to "ON/RUN".5) DO NOT start or attempt to start engine.6) The message "DIAG" should appear on left LCD screen along with a number indicating the Fault Code.7) We strongly recommend paying your Aprilia dealer do all of this.
Component Fault Code Possible Cause Camshaft position sensor 11 Sensor not connected. Sensor broken.
Wiring faulty.
Crankshaft position sensor 12 Intake pressure sensor 13 Intake pressure sensor 14 Excessive pressure difference between two pressure sensors Throttle position sensor 15 Sensor not connected. Sensor broken.
Wiring faulty.
Coolant temperature sensor 21 Air temperature sensor 22 Atmospheric pressure sensor (inside ECU) 23 Sensor faulty Ignition coil 1, Front cylinder 33 Ignition coil faulty or wiring not connected Ignition coil 2, Front cylinder 34 Ignition coils 1 and 2, Front cylinder 33,34 Ignition coil 1, Rear cylinder 35 Ignition coil 2, Rear cylinder 36 Ignition coils 1 and 2, Rear cylinder 35,36 Fall Sensor (tip-over sensor) 41 Sensor not connected. Sensor broken.
Wiring faulty.
