i dont want it like chrome, i think the picture longer up here was cool.
but anybody know what the rims are made of?
Stock Aprilia Ditech 03 model(Morini)
Derestricted variator
6,6g rollers
molossi powerfilter
NGK ZMR7AP
I would be happy with those, even though they are just polished =)
Plus they are for sell for 200EUR + shipping =D but the rear is minarelli
Plus, someone was asking about the Kiesler adapter. It was made to fit the Kiesler rim to a Piaggio/Gilera engine (which come with the 5 lug hub). Since the new Aprilia already has the 3 lug hub, you do not need it. I still use one with the Galfer brake disc, but only because I still had it from my previous build.
Does anyone have the "Gyronetics" rims? The "Spider" design is sick. Dont like the others so much though. "Black Diamond and "Black Ghost"
Cool rims
http://www.sip-scootershop.com/en/pr...ider+_gn020010
Aprilia SR50R 08 - Spiderman Edition | MHR BigBore 86cc 50,00mm Cylinderkit | MHR Team Crankshaft | MHR EPROM Ignition | MHR M.A.C.S.I PowerBox | MHR VITON Manifold | MHR 28mm VHST Carburator | MHR E15 Powerfilter | MHR VentilVar | MHR VL16 Oversize Reed Valve | MHR BigBore Exhaust | MHR Overrange Team Multivar 2010 Variator @ 4g Dr.Pulley Rolls | Dr.Pulley HIT Clutch @ Green springs | Dr.Pulley 2010 ClutchBell | Malossi Blue 106% Contra-Spring | MHR Overrange Kevlar belt | Malossi Torsion Controller | MHR 13/48 Secondary Gearing | MHR HTQ 14/39 Primary Gearing | MHR Overrange Torque Drive | Kiesler Waterpump | MHR DENSO IW34 IRIDIUM Sparkplug | Nology "Hot-Wire" Sparkplug Wire
I like that look... Wow... that could rock on the scooter. Price is good too.
Why is it for "RACE ONLY" design? or just not DOT rated etc?
Will the rims work on a SR50?
What adapter is needed?
No adapter is needed. They will fit on perfect.
No e-pass, no safety certification
Ahh figured it was a safety thing. looks like I'll be getting the matte ones I think! Looks so good. Hard to pick
I'd like to see a wheel that looks equally nice from either side.
Shrubman
2009 SR50 R Factory
Engine:
HGT PFI Conversion
HGT-Modded Bing 26mm Throttle Body
Malossi 86CC Cylinder
Malossi MHR Big Bore Exhaust
Malossi VL13 Reed Valve
Pro Porting Intake Manifold and Spacer
Pro Porting Double Layer "Air Plus" Air Filter
Transmission:
Malossi Multivar 2000 MHR Team (2008 Model)
Malossi 14/39 Primary Gears
Malossi Delta Clutch
Malossi Kevlar Belt
Other:
Stage 6 Adjustable Shock Riser
HGT Billet Aluminum Brake Levers
Buzzetti Side Stand
Motorkit Rear Hugger
How is ordering from SIP? They quoted only 56$ for next day Fedex service to Washington State... Which seems odd.. because they then quote UPS standard at 380$ for 6 day service.. haha
