Colin Edwards Replica #60 Sato Rear Sets,16t front,Evoluzione turnsignal conversion kits & low temp fan
switch, R & G Front and Rear Sliders
2002 Futura #507 Blue, Bembo radial clutch & brake master, Galfer brake kit, StainTunes with H-pipe, PCIIIUSB, 109HP on the Dyno
RaceTech rear shock and gold valve front forks
I got a call from my suspension guy last week. Turns out he was in the process of doing one of these shocks on a Futura and wanted to know the best way to pull the stock shock and install the new one. I was amused that a suspension guy would call ME to ask!
Ron
MSgt USMC (Retired!)
Semper Fi!
Nesba A #45
IBA #38812
RST Futura
RS50
That was AFTER he pulled the exhaust trying to see if he could it from the bottom. He woulda finished it that day had he called me first!
Ron
Semper Fi!
Nesba A #45
IBA #38812
RST Futura
RS50
"Yes it is some money but you said whole Futura is a good price but it will still have bottom of the line suspension. I have a few thousand miles now with the RaceTech upgrade and its the best thing I have done on this bike.."
Good to hear. Have you done anything with the front end? It's time for me to do some suspension work or get a new bike. Test rode a Sprint and a 1200R and realized the RST is still one hell of a bike!
2001
staintunes, CF hugger, Race Tech shock,
Magnecor leads, Brembo radial pumpers,
K&N, de-restricted,voltage monitor, FPR mod,
Falco showa fork in progress
Where does the remote preload mount?
2001
Bringing this one back up to the top. Has anyone else bought the RaceTech since Lynnup? Other priorities popped up before I could buy one. I will have a new rear shock for next year, either this one or a Penske.
2004 Tuono...Red (Sold)
2002 Futura...Black
2008 Akita.....Red
My thought is go for the little guy.. Penske does not need any more money and I think RaceTech could. I'm still happy with mine.. just my thought
I know of one Futura in North Carolina that has one fitted up by Cogent Dynamics.Has anyone else bought the RaceTech since Lynnup?
Ron
Semper Fi!
Nesba A #45
IBA #38812
RST Futura
RS50
Meanstrk,
Yep, that's my Futura that's fitted with the RaceTech shock + Ohlins valves and RaceTech springs in the forks. It was pricey, but definitely worth the money. The bike tracks like it's on rails, and the front and rear actually work together now rather than fighting each other through the corners. Rick at Cogent Dynamics did a great job and had the suspension dialed in pretty well when I went to pick it up. We fine tuned the suspension with a shake out ride.
I purchased the Brembo brake and clutch master cylinders and braided steel lines kit from AF1. They should be going on in the next couple of weeks.
Regards,
Dave
I'm currently talking with Rick at Cogent Dynamics about my bike. He is suggesting I send the forks to him for Ohlins internals and doing the RaceTech shock. I'm definitely going to send him the forks but am not sure I need all that shock. But he did mention your bike, Dave, and said it is amazing. He said it felt like it lost 150 lbs after the suspension work.
Kurt
03 Futura
88 Honda Hawk GT
kurts,
Curious when you say Ohlins internals, are going to run the 20mm Ohlins valves or something more?
I have run that setup but it was not sorted properly by the guy I had doing my work previously.
It is funny my bike is now the opposite of Dave's in that I am running an Ohlins shock revalved and resprung, and now I am running a set of Ractech 25mm cartridges in the Mille forks.
Terry
Too little time, Too many Bikes!
01 FUTURA
MODS LIST;
RaceTech 25mm cartridges in Mille Forks, Ohlins rear shock with custom valving,
320mm Rotors, Brembo 4 pad calipers, SS brake lines, Ferodo ST front pads, Radial master cylinders (both),
mille air boot,AF1 H-pipe, Staintune Exhaust,
Mosfet RR, rectifier wiring mods done, metal fuel disconnect done,
Aux relay installed to run seperate wiring for accessories (garmin, escort 9500, and an amp with volume control for earbuds)
CBR1000RR mirrors,
01 MILLE 'R (trackbike)
00 ZRX1100 (WIFES BIKE)
78 RD400 (WIFES BIKE)
IBA MEMBER #48709
You know Terry, I don't honestly know yet. It was referred to as an Ohlins "kit" but we haven't gone into the details yet. Once I'm ready he says to give him a call and we'll discuss the particulars. This is still in the planning stage and I'm still trying to determine what I need. Regardless, I'll pull the forks next week and get them shipped off.
Kurt
03 Futura
88 Honda Hawk GT
Kurt,
The Ohlins kit uses 20mm valves, but you've got to replace the springs, too. I took Rick's recommendation and used RaceTech springs up front to go along with my RaceTech shock in the rear.
If you're going to do suspension work, you might as well do both. You will never truly get the performance gains you're looking for if you only fix half the bike's suspension. One of the best things about the work on my bike is that it made the front and rear feel like they were finally working together instead of fighting each other.
Regards,
Dave
Terry
01 FUTURA
MODS LIST;
CBR1000RR mirrors,
IBA MEMBER #48709
