57mm throttle bodies off an 04+ RSV Mille, low use and good upgrade for pre 04 RSV and first gen tuono's. Missing tps, but if swapping out existing tb's simply use your existing tps. $200
I am the Nightrider! I am a fuel-injected suicide machine! I am a rocker! I am a roller! I am an out-of-controller! I am the Chosen One! The mighty hand of Vengeance! Sent down to strike the unroadworthy! I'm hotter than a rolling dice! Step right up, chum, and watch the kid lay down a rubber road right to freedom!
Anyone want to make an offer?
I sent you a PM
Aaron
'01 Blue Mille, Ohlin's rear shock, Carbon Fiber fenders
I can help with broken chip pins and other chip problems or questions!
Is this a straight swap other than TPS?
Funny quip goes here
Sold!!
