Page 1 of 24 12311 ... LastLast
Results 1 to 15 of 348
Thread: 86cc Malossi Replica Build... In progress
    Parker Colorado
    The owner gave me permission to post his build so I will keep this thread open and document what goes into this. The Scoot arrives in the morning and the Malossi parts are already ordered. I will be finishing the current 86cc PFI Piaggio build while this block is out for machining and powder coating.
    Myself and the owner both have a pretty good idea of the direction it will take right down to the Malossi paint scheme above.
    Sep 2008
    Nice weather AT LAST! Winnipeg, MB
    THAT will be one sweet bike!! Both in looks and ability!!
    I assume that you will also Dyno it?
    Anger is an ugly Mistress…
    Banned Snugg's Avatar
    Aug 2007
    Aurora, CO
    Fantastic! I'm looking forward to this build. It's going to be a screamer.
    apriliaforum expert Culverin's Avatar
    Nov 2009
    Vancouver, BC, Canada
    Doesn't that mean it'll be a carb build?
    SR50 R Factory / 2009 / Piaggio Purejet
    General
    Restrictions: Removed / Tires:
    Michelin Pilot Sport SC 130/60-13 (front and rear) w/ 2.0g dynabeads / Rider Weight: 56.7kg (125lbs)
    Performance
    ECU: unknown Version and Mapping
    Spark: NGK ZMR7AP (gapped to approx. 0.037mm)
    Exhaust: LeoVince GP, silencer removed
    Variator: Malossi Multivar 2008 w/ 6.0g DP sliders
    Contra Spring: Malossi Purple w/ Malossi Torsion Control + Stock Piaggio TC (clutch side).
    Clutch: Malossi Delta / Yellow Clutch Springs (7250 rpm engagement according to this table) / Wing Clutch Bell
    Reed Cage: Malossi VL13 (stuffer removed)
    Status
    - Clutch might still be engaging too soon? Too late? Not really sure?
    - Off-the-line lag is gone. woot.
    Parker Colorado
    I want to show Malossi how we do it here so the plan is Port Fuel.
    apriliaforum expert MeepMeep's Avatar
    Jul 2008
    Mass
    sweeeeeeeeeeeeeet!!!! I cant wait either!!!!!!!!
    2009 SR50R Factory diablo white
    Currently getting the HGT replica WORKS!
    2002 SR50 Ditech Haga SBK replica
    70cc malossi BBK w/ecu
    blue aprilia 7075 ergal bolt kit
    blue aprilia 7075 ergal bar ends
    malossi delta clutch
    malossi reed block
    Aprilia Paoli adjustable shock
    Installed Pussy Magnet
    Sep 2008
    Careful Rich… They just may pull you out of Retirement!!!
    Parker Colorado
    I will need to speak with Dynojet as they say the Scooter Dyno is 30HP and 109 mph... I have a really good feeling I will be exceeding the 109 mph.
    Sep 2008
    If that happens, and you send Malossi (and post on You Tube as well) Video “proof” of that speed, I have a funny feeling that your work load may just increase (and NOT just from within the US!!)!!!!
    I would also think that they just may want to come vist you and your shop after a posting like that!!
    Jul 2008
    Mass
    Quote Originally Posted by Grenadiers View Post
    If it wasnt so expensive to ship, id send all my work there. there has been 2 sr50's for sale localy lately that were failry cheap, semi rare schemes, and would make killer PFI conversions. one was a harada, the other was that banana yellow. both were 2000 carb models..... I am still contemplating one of them,
    can you imagine going that fast on 12 in wheels? scary eh? I awlays thought a malossi rep would be rockin
    malossi reed block
    Apr 2009
    Minnesota, USA
    Even with your 1:1 gears? Without the variator transitioning mph is determined by engine rpm, I wouldn't think you're turning enough rpm to hit 109?
    '05 Piaggio Typhoon
    Engine: Piaggio 125
    Exhaust: JollyMoto 180
    Intake: MHR VL13/SR50 Air Box
    Brakes: MHR Red/TNT "Carbon" Levers
    Gauges: KOSO GP
    Parker Colorado
    Would you like to make a wager
    apriliaforum Junkie Molino's Avatar
    Nov 2009
    .Boston
    I bet 5£ on HGT.
    So what type of engine is this Malossi build going to use?
    2007 Morini SR50
    Malossi 70cc BBK , LeoVince ZX-R & 7.0g Rollers,
    BGM LED Taillight, Ferodo Platinum Brake Pads,
    Marchald Pro Porting Pod Airfilter, NGK ZMR7AP,
    MHR VL12 Reeds, Malossi Galfer Front Rotor,
    Polini Kevlar Trans Belt, Royal Purple 75w80 Gear Oil,
    Kobalt Water Trap, Amsoil Saber 100:1 Full Synth 2t Oil,
    STR8 Carbo Look Shock Riser, Buzzetti Sidestand,
    Avon Viper Stryke Rear 140/60, Stainless Steel HEL Brake Lines
    Top Speed: +-65mph
    Parker Colorado
    Quote Originally Posted by Piaggio50 View Post
    I can hit 100 true MPH now with my Harada at 14,500 rpm and that has a mild primary gear set only. The Malossi Replica will be geared up on the primaries and secondaries.
    Apr 2009
    Minnesota, USA
    I don't doubt for a second you'll hit 109 with the variator, just don't know why you would dyno through it when you have the 1:1 gears available. What's top gear in the variator, 5:1 maybe? To hit 109 through the 1:1 you'd have to be geared to 500mph through the variator.
    '05 Piaggio Typhoon
    Engine: Piaggio 125
    Gauges: KOSO GP
