Page 1 of 5 123 ... LastLast
Results 1 to 15 of 63
Thread: Castrol RS TTS 2T- Discontinued :(
    apriliaforum expert captdan's Avatar
    Apr 2010
    Florida
    I heard a rumor that the Castrol RS TTS 2T was being discontinued. I contacted Castrol USA and they confirmed that it is being discontinued and that they have no plans of replacing it. So if you are like me and canít see yourself living without it, purchase what is left on the shelves. Today is a sad day.
    2009 SR50 Factory
    20 mm Bing Throttle Body
    Water Trap (Kobalt tapped with 1/4" NPT brass drain)
    Castrol Power RS TTS
    Castrol Syntec Gear Oil- 75W-90
    Oil Pump Flow Increased
    NGK ZMR7AP-(.030-.032) (Indexed @ 12:00)-
    Leo Vince ZX-R
    Malossi RS24 Rear Shock
    5.0 and 5.5 DP Sliders- Red Springs
    8mm Mirror Risers/Extensions + 30mm Washer
    Aprilia Emulsion Bleed Valve
    LED Tail/Brake Light
    Black Tunnel Covers
    Rear Tire- Pirelli Diablo Performance 140/60P-13
    Front Tire- Pirelli SL 26 Performance 130/60LX-13
    Top Speed (Digidash)-50-51 MPH @ 9100 RPM (Flat Road/Tucked)
    Rider Weight- 215 lbs
    22,200 miles-11/2013
    Yeah, Coulda' Bought A Harley- But Chicks Dig Scooters!!!!!:
    apriliaforum expert Haribolman's Avatar
    Gold Coast
    Quote Originally Posted by captdan View Post
    Hope they don't do that here in Oz...I wouldn't know what else to use!
    Go Vegan!
    ASM - CBT - EFT - NVC
    M - P - SIP
    BOM - IMDB - NEWS - UFO
    I & L
    Silver 2007 SR50 R Factory
    Haribolman has promoted SAFE RIDING for over 30 years.
    Life is precious. Be proactive and responsible.
    Always wear a helmet, gloves, jacket and safe footwear.
    (This signature was approved by my legal representative)
    apriliaforum expert Culverin's Avatar
    Nov 2009
    Vancouver, BC, Canada
    Bloody hell. I'm on my last bottle.
    I seem to have used up 3.5 bottles in about 2000km. Does that sound about right to you?
    Time to put in a large case-order to point roberts. The border guards are going to give me their usual "wtf" when I cross. In the last few months, I've brought back a commercial stainless table and a 7-foot long sink among various oddities. hahahaha
    SR50 R Factory / 2009 / Piaggio Purejet
    General
    Restrictions: Removed / Tires:
    Michelin Pilot Sport SC 130/60-13 (front and rear) w/ 2.0g dynabeads / Rider Weight: 56.7kg (125lbs)
    Performance
    ECU: unknown Version and Mapping
    Spark: NGK ZMR7AP (gapped to approx. 0.037mm)
    Exhaust: LeoVince GP, silencer removed
    Variator: Malossi Multivar 2008 w/ 6.0g DP sliders
    Contra Spring: Malossi Purple w/ Malossi Torsion Control + Stock Piaggio TC (clutch side).
    Clutch: Malossi Delta / Yellow Clutch Springs (7250 rpm engagement according to this table) / Wing Clutch Bell
    Reed Cage: Malossi VL13 (stuffer removed)
    Status
    - Clutch might still be engaging too soon? Too late? Not really sure?
    - Off-the-line lag is gone. woot.
    apriliaforum Member dfxdig's Avatar
    May 2010
    myrtlebeach sc
    strapped to the back of your bike?
    2010 sr50 factory
    piaggio motor
    ecu- 2.8.0
    plate and ring removed
    zx-r exaust, woodruff key
    delta clutch, molassi tc
    molassi torque drive
    pod filter, v13 reeds
    agip city 2t
    1000 miles
    water trap
    gen III hgt fuel reg
    multivar 2000
    Apr 2010
    Florida
    QUOTE=Culverin; Bloody hell. I'm on my last bottle.
    Gosh, Are they 1 liter bottles? If so, that seems like quite a bit for 2000 km's. Off the top of my head, I think Im getting around 2000 miles on 1 liter of oil. Maybe someone else can chime in.
    Yep, Im not happy with Castrol right now. They recently changed the formula of their top tier 4 cycle oil (again), so they have been rather inconsistent as of late. To that end, I just ordered 9 liters of the RS TTS 2T from a place in California so that should hold me off Ďtill Iím at least ready for a BBK.
    2009 SR50 Factory
    Leo Vince ZX-R
    Black Tunnel Covers
    Banned High Gain Tuning's Avatar
    Parker Colorado
    This is much closer to normal... Culverin I would re-evaluate your consumption.
    apriliaforum Member B 52's Avatar
    Jun 2011
    Greece
    Quote Originally Posted by Culverin View Post
    Do you drink some of the oil instead of putting it into the tank? :p
    Oil consumption for di 2stoke as far as i know is about 900ml to 1Litre per 1000kilometers.
    -Aprilia SR Max 278cc
    Nov 2009
    I might have mispoke, but I'm not off by much, I'm about 3 bottles in, not 3.5. The bike doesn't seem to be having any leaks. Any idea what could be eating up all the oil?
    General
    Performance
    Status
    Parker Colorado
    A stuck or misadjusted pump. Pull the rubber plug off the variator cover and post a pic of the pump setting
    Nov 2009
    Okies, will do. What part of the oil pump specifically am I looking for?
    Vancouverites,
    I'm going to put grab up quite a few bottles from the states. Let me know if you want any?
    General
    Performance
    Status
    Parker Colorado
    The rotational front piece that the throttle cable is connected to. Make sure it rotates with the throttle.
    Nov 2009
    How does this look?
    It's rotating matches the throttle.
    General
    Performance
    Status
    Sep 2008
    ďI reject your reality, and substitute my own.Ē CANADA
    If I'm not mistaken... it's supposed to. It regulates the amount of oil that your engine gets...
    Tempus Fugit
    Parker Colorado
    Your pump is set a little lean on the oil. This happens because the cable stretches over time. The 2 red lines should line up at closed throttle. You adjust it at the arrow.
    apriliaforum expert rhino666's Avatar
    May 2010
    PROUD to be a American Living in the USA.
    Some luck for once! Castrol RS TTS 2T "SIP ANYONE"
    Bought 2 cases =24 paid $5.50ea.free shipping. no longer offered
    [IMG][/IMG]
    Feel free look at my small collection of aprilia scooters
    Tap picture to view the photo's and enjoy
    2003 APRILIA SR50 SPORT-PRO 900mi SUPER MINT CONDITION, MORINI MOTOR AND A NEW 2009 APRILIA Dietech SR 50 FACTORY 300 miles like new condition
