Results 1 to 15 of 20
Thread: Tuono Aftermarket Footpegs?
    May 2011
    Missouri
    Hi, just bought a very nice 07 Tuono. After riding twisties all weekend, I discovered my boots seem to not get much grip on the pegs, especially the left. Even causing some up-shifting when I didn't want to. I've been searching for replacements with no luck. I don't want new rearsets, just pegs...any suggestions appreciated.
    Thanks.
    apriliaforum Junkie quadracer's Avatar
    May 2010
    Derby, Indiana, USA
    A little creativity with a Dremel tool might do the trick alot cheaper than new pegs.
    07 Tuono
    04 Honda 599
    04 Suzuki Z-400
    Quote Originally Posted by ZutAlors View Post
    Praise the lawd and pass the ammunition?
    May 2011
    Missouri
    That's a thought, thanks.
    apriliaforum newb Magni Man's Avatar
    Mar 2009
    Austin
    woodcraft-cfm. Great products, simple and priced well.
    Kevin
    1953 Benelli Leoncino
    1983 Magni MB2
    2007 MV Agusta F4
    2008 Aprilia Tuono Factory
    2012 Aprilia RSV4 Factory
    apriliaforum Junkie catch2otwo's Avatar
    Jan 2008
    san fran
    07.5 Tuono
    Mar 2009
    Austin
    You can get them from AF1
    Kevin
    1983 Magni MB2
    2007 MV Agusta F4
    apriliaforum Member aaron field's Avatar
    Jan 2010
    victoria/australia
    I have a set of Woodcraft rearsets if you are interested.For me I found that it was werth spending a little more. So i went for the Aprilia Performance product rearset`s and they are supperb you cant go wrong with this product.
    May 2011
    Missouri
    Thanks for the info...so I'm not all that keen on cutting off the ears and bolting on a non-folding peg, and really don't want the expense of rearsets. Just looking for more grip, I like where the pegs are placed.
    AF1 has pegs? if so, I'll do a search. thanks again.
    Jan 2008
    san fran
    Quote Originally Posted by whitegoodman View Post
    AF1 has the pegs that are used in the DIY mentioned above. You could try adding skate board grip tape to the tops of the knubs on the existing pegs.
    07.5 Tuono
    apriliaforum expert Pieman_tm's Avatar
    Apr 2009
    Kent UK
    Are these any good?
    [ame="http://cgi.ebay.co.uk/APRILIA-RSV1000-MILLE-VALTER-MOTO-REARSETS-/120614249517?pt=UK_Motorcycle_Parts&hash=item1c152 b642d"]http://cgi.ebay.co.uk/APRILIA-RSV1000-MILLE-VALTER-MOTO-REARSETS-/120614249517?pt=UK_Motorcycle_Parts&hash=item1c152 b642d[/ame]
    Jul 2004
    Point Lonsdale, Australia
    I once etched pegs with a Dremel as per a previous suggestion and it worked well.
    I think these guys make pegs. It's worth a look at their products anyway. Some nice stuff!
    http://www.llsracing.it/lls_eng.html
    Apr 2010
    Ca, USA
    new boots
    you could try differnt boots with more agressive tread
    apriliaforum prov-nov rnr's Avatar
    Jul 2007
    east tennessee
    LSL (Spiegler) has pegs with an OEM adapters. Galfer makes them and Rizoma makes them. Neither Galfer nor Rizoma list the pivot adapter for the Tuono. I used the LSL fitment chart to find that GSXR's 08+ use the same LSL pivot piece as the Tuono. So, in a couple of weeks when PJsparts.com moves down here (a couple of miles from my house) I'm going to go by and check to see if the Rizoma pivot piece will work with the T. I'm sure the width and hole will work...I'm wondering if they will lock out on the level or be tilted up or down.
    I'll report back my findings. This is an issue for me as well; want sharper pegs, but have no desire to change there position.
    apriliaforum prov-nov Technoz's Avatar
    May 2012
    OHIO Northeast
    I just did the Woodcraft peg install described at the joe250 link....and I love these pegs!!!,,,,,,so much better than stock....especially when flying home from work wearing steel toe work boots.
    I cut the stock tabs off...(dam, wish i had a Milling Machine again!)...by hand with a air powered cutoff wheel....then emery cloth on a flat surface...came out great, and I highly recommend it.
    Nov 2006
    Houston
    Gilles are very nice. And now my rear brake works.
    Bikes:
