Results 1 to 8 of 8
Thread: Aprilia sr 50 Ditech Wont start
    Jun 2011
    Sweden
    Exclamation Aprilia sr 50 Ditech Wont start
    I got a problem with My Scooter Aprilia Di tech 02 Aprilia engine.
    I were out Driving but all of the sudden it started to go a little slower than i turned home and soon as i had stop the engine shut of, and wouldn't start again, What can the problem ? It gets fuel, The spark plug is wet, The Spark plug have a Good spark. Its Ignite its Starts 1 mili sec than it turns off again Any one got any ideas ?
    Its almost like this
    ( Sorry i am from Sweden so my native is not English)
    [ame="http://www.youtube.com/watch?v=makK5bmCUm8"]YouTube - ‪Aprilia ditech strarting problems‬‏[/ame]
    Jun 2011
    Sweden
    And the injection Check lamp blinks 9 Times when i do the test,
    Sep 2008
    I reject your reality, and substitute my own. CANADA
    Welcome to the Forum!!! If you haven't already done so, you should read the Sticky "Read Me First!" In there you will find TONS of VERY useful information!!
    Check and report back any ECU codes, check the Air Compressor Line for leaks with a soapy water soloution (when you do get her running).
    Check the engines Compression and also check to see what the pressure of the Fuel Pump and Air Compressor are producing.
    Replace the Sparkplug with a new one gaped to between .035 to .040 (DO NOT go with the gap of a new sparkplug out of the box as it is too narrow and for a generic vehicle use) The plug's gap is important!!
    Tempus Fugit
    Sep 2008
    Quote Originally Posted by Carlsson94 View Post
    If this is so, you may have a faulty/failing ECU...
    HERE is a link to my thread that explains what the codes means and items to check...
    Tempus Fugit
    Jun 2011
    Sweden
    Yes, i have Check so its no any leaks any were and i dident find any thing in The sticky and i just replaceed the Fuel pump, and about the ECU i tested 3 Diffrent The first on My orginal shows 1 Blinks and than 8 Blinks, The secend Shows 9 Blinks and the last one Dosent show a thing than the lamp is just turned on,
    I also wanna thank you for the codes than be useful!
    Will Check all the parts later today
    May 2012
    chicago
    NO ONE CAN FIND THE READ ME FIRST STICKY. apparently.
    apriliaforum expert Snugg's Avatar
    Aug 2007
    Aurora, CO
    Quote Originally Posted by uziXwraith View Post
    ?? You do know this is a year old thread right?
    apriliaforum Member nexlvlsh!t's Avatar
    May 2012
    Vancouver
    el o el ............
    2007 SR50 Factory
    Reed valve -MALOSSI MHR VL14 Aprilia 50cc Morini - carbon fiber
    Malossi multivar 2000 Morini
    Porter Cable Water Trap
    Woodruff key -TOP PERFORMANCES 3x5mm- Morini 50cc 2-stroke
    Exhaust -LEOVINCE ZX-R- DiTech LC (Morini) Installed 06/01/2012
    Stickers Removed
    Derestriction ECU map 2.8.2
    HGT Gen III Fuel Regulator
    LED Headlights
    Custom License Plate LEDS
    Malossi Air Filter
    Malossi Belt
    Dr Pulley 7.0g Sliders
