Results 1 to 5 of 5
Thread: Trans Cover Bolt Missing?
    May 2011
    Temperance, Mi
    I have a 2010 SR50 R Factory that I'm derestricting and have a little brain fade going on. I took it apart over a week ago and have it almost all the way back together, but thought I lost a trans cover bolt. I was looking at the parts diagram and see 1 of the holes in the trans cover does not have a bolt, is this correct?
    Please see attached PDF file.
    Thanks,
    Chris
    Attached Files Attached Files
    apriliaforum Member 750SHIVER's Avatar
    May 2008
    Sterling Heights, MI
    My scoot is a 2009. I have the side cover off right now and have a bolt for every hole. However when it get put back on, I will leave the very front lower one out. Its a pain in the butt to get at with the lower fasia on.
    Then maybe someday when I get the CVT tuned just right. I will stick it back in there.
    I could not get your file to open.
    Keith
    ( Temperance, MI ) Good to see another East sider on here!
    2009 SR 50 FACTORY WHITE
    2.8.0 ECU MAP DE-RESTRICTED ( RING & PLATE )
    LEO VINCE ZX-R PIPE
    MALOSSI 70cc BIG BLOCK KIT, Gasket matched.
    20mm intake and TB. ( Bored out )
    Malossi 5.5 rollers ( 5.1/5.7 mix )
    Red springs
    HGT Gen 2 black fuel regulator set at 130 PSI
    Malossi VL13 reeds
    NGK laser platinum ZMR7AP spark plug
    New top speed of 60 MPH flat ground.
    apriliaforum Member NME's Avatar
    Charlotte NC.
    This is just a shot in the dark but I have left bolts in the clips that hold the rear brake line to the case and forgotten that they were still in there.
    2009 SR FACTORY
    Derestricted
    Water trap
    Leo ZXR with supplied springs and rollers
    3 degree key
    Malossi MHR reeds w/o stuffer
    Questionable cylinder
    May 2008
    LOL!!!!!! Your not alone.
    To funny.
    Keith
    LEO VINCE ZX-R PIPE
    Red springs
    Malossi VL13 reeds
    May 2011
    Temperance, Mi
    Thanks Shiver, see if it will open now? I just bought this thing 3 weeks ago and came across HGT's website, and the fun began. Rich set me up with a GP pipe and derestricted my ECU. I bagged and labeled all the other screws when taking it apart except for those for the trans cover.
    I found this thing used with 12 miles on it and thought this would be a fun toy to play around on. My friends laugh at me because I already have 2 Harley touring bike as well.
