Results 1 to 15 of 17
Thread: image of sight glass on sxv 550
    Harvard, MA
    Could someone post an image of the oil level sight glass indicating its location.
    Thanks -
    Jan 2008
    Michigan, USA
    No pic at work but....
    Quote Originally Posted by Moran View Post
    Thanks -
    It's not a sight glass on the side of the motor but a clear tube which is on the side of the oil tank. Look in between the right side radiator and the frame. You need to have the motor completely warmed up to get an accurate reading so after you ride for 6~7 minutes is when you should check it.
    '11 BMW F650GS (twin)
    '12 KTM 450 XC-W
    '04 Ducati Multistrada 1000
    '09 Scarabeo 200 (wife's)
    '01 Scarabeo 150
    '68 Suzuki KT120
    Harvard, MA
    Thanks - perhaps with your detailed description I won't need the image. I knew it was a clear tube much like the obvious one on my 2003 Tuono R but, embarrassing though it may be, I'll be damned if I've been able to find it. Now with your directions I'll look again.
    Thank you -
    apriliaforum Member Surfingbuddhist's Avatar
    Feb 2010
    Santa Monica
    it's on the front of the oil tank, right behind the front fender....
    '70 Honda CB350 Cafe
    '05 Honda CRF 450R
    '09 Aprilia SXV 5.5
    '10 Ford SVT Raptor
    Harvard, MA
    Oil Level Tube
    I'm either visually impaired or stupid or perhaps both but, although I see an oil-filled clear tube on the left side, I see no clear tube on the right side and no "min/max" markings on the left side tube though it's full of oil. Below are photos of what I think are the pertinent left and right side areas.
    Feb 2010
    Santa Monica
    here..
    '05 Honda CRF 450R
    '09 Aprilia SXV 5.5
    '10 Ford SVT Raptor
    Harvard, MA
    Thanks - I'll let you know if I find it.
    Harvard, MA
    As my photos might have hinted, I've been looking for the tube on the rear of the tank. One glance from the front revealed the obvious. It apparently was stupidity or my excuse is I'm used to checking oil level while seated on my Tuono. Thanks again to all for you help and patience.
    Dec 2010
    FOREST, VA
    Moran...... your welcome.....
    I noted your address........... Hmmmm......
    If it was MIT....... there might be some ribbing included.....
    Harvard, MA
    Not quite - that's the town of Harvard not the University. Still, I'm pretty ashamed.
    Jan 2010
    New Zealander (No fixed abode)
    That tube that you say is full of oil - probably shouldnt be. Its the drain tube from the airbox. Drop the sump pan down and remove the bung from the end of the tube. Then keep an eye on it, if it is getting oil in it you may be overfilling your oil tank. Although after a race or really hard ride it may be normal to see a bit in there.
    '07 SXV4.5
    Jun 2007
    australia
    I would drop the oil and put 1250ml back in it. The engine needs to hot before you can read the level in the tube. Check your gearbox level aswell as they could be mixing.
    apriliaforum Member maple2's Avatar
    Feb 2010
    Massachusetts
    tough livin here, aint it? Harvard- they always think "university" when ever you go over the Mississippi, they think Mass is "Boston" then ask you how the Kennedy's are. shallow bastards
    #64 Xtreme Powersports/ Vibram Soles/ Racing Aprilia V-twin
    apriliaforum expert jay dub's Avatar
    Apr 2010
    OREGON
    You've got quite a few punter states out there maple... On the west coast we have 3 states. It gets confusing for us w/ ther bordders east of the mississippi.
    acab
    Harvard, MA
    Thanks for the advice on the oil-filled tube. I'll leave the coastal combat to others.
